Discuss
drum wont turn with a normal load
 in
Dryer Repair
Matag SDG3606AWW Dryer I have just replaced the (1) motor (2) belt (3) drum support rollers (4) drum glides and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » drum wont turn with a normal load
  #1 (permalink)
Old 04-25-2012, 11:42 AM
Junior Member
fred bruning is on a distinguished road
Default drum wont turn with a normal load
Brand: Maytag   Age: 1 - 5 years
Matag SDG3606AWW Dryer I have just replaced the (1) motor (2) belt (3) drum support rollers (4) drum glides and felt (5) idler arm and pulley assembly and (6) spring. The dryer will now start and the motor will turn the drum but when I put in a normal load the drum will not turn. any suggestions.
Ads By Google
  #2 (permalink)
Old 04-25-2012, 02:06 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check if the belt installed correctly and if the drum turns freely.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-25-2012, 05:08 PM
Junior Member
Default drun won't turn
yes, the belt is installed per the forums advise and yes the drum turns, it will turn with just several garments but will not turn with a normal load
  #4 (permalink)
Old 04-26-2012, 10:28 AM
Expert
Default
Hi.
There is no miracles. Please double check everything you installed. If all checks OK - then, possibly you have bad motor.
The motor Part number: 2200376
Thank you.
Simon.
__________________
  #5 (permalink)
Old 04-26-2012, 02:01 PM
Junior Member
Default drum won't turn
FYI, the belt diagram in the forums post for this model #SDG3606AWW is wrong. Matag's adivce for this model is that the ribs of the belt go against the drum "NOT Away" as the forums' diagram shows. http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html Please change the information as I'm sure it has caused others problems similar to mine.When I reversed the belt with the ribs facing the drum the the drum turns with a full load and the dryer works great. thanks for your response
  #6 (permalink)
Old 04-26-2012, 02:41 PM
Expert
Default
Hi, Fred.
Sorry for the troubles and thank you very much for the correction. We' ll take care of it ASAP.
Thank you again.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front load will not turn drum. $1.00 part? Sparky913 Washer Repair 1 12-29-2011 07:15 PM
dryer drum wont turn under load steelers20 Dryer Repair 0 08-08-2011 07:05 PM
LG Front Load-LE Code- Drum wont turn sleddoc Washer Repair 10 05-31-2011 12:13 PM
Dishwasher wont turn on. NORMAL light keeps blinking. cpspoerl Dishwasher Repair 0 12-31-2010 03:45 PM
Drum wont turn beachboy Dryer Repair 1 05-06-2009 09:13 AM
