how do i wire the 3 wire door switch do you have a wireing digram for this dryer. thanks charles moss
It is a GE so getting any tech info is near impossible. They like to keep everything a secret. Here is a link with some sample GE wiring diagrams. http://www.applianceaid.com/diagrams.htmlWith luck your will be close. The wiring color code may be different but Neutral should be Common and Normally Closed should go to the drum light. So the third wire (motor or timer) goes to the Normally Open, |
THIS FORUM IS DEAD!!!!!!! |
