Discuss
Frigidaire Dryer Has No Heat
 in
Dryer Repair
Hi. I recommend you to replace the motor and individually connect the wires without the plug. Also cut off the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Dryer Has No Heat
  #21 (permalink)
Old 07-16-2012, 10:00 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
I recommend you to replace the motor and individually connect the wires without the plug. Also cut off the overheated area and put a new contact on the heating element wire. Make sure the connection is tight.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #22 (permalink)
Old 07-18-2012, 11:02 AM
Junior Member
moody9207 is on a distinguished road
Default
Are you saying to cut away the burned area on the plug for the yellow and black contacts, and install them individually, and then use the remainder of the plug for the gray, white, beige and green contacts? I think I would prefer to do this. I could not see an easy way to remove the good contacts from the plug.
I understand to cut off the burned wires at the heating element and replace with a new connector.
Regarding the new motor, I see now that it is already in a cage (see attached pic). It looks like there is a clip on either side of the old motor that holds it down, correct? My other question is regarding the blower housing - does it simply spin off of the shaft? I do see the threads on the shaft of the new motor.
  #23 (permalink)
Old 07-18-2012, 12:50 PM
Expert
Default
Hi.
You can connect the wires as you wish as long it's done properly.
The blower is threaded on the shaft.
Thank you.
Simon.
__________________
  #24 (permalink)
Old 08-11-2012, 03:05 PM
Junior Member
lexmp0523 is on a distinguished road
Default
hey did changing the motor work for you? I have the same problem anyone help? I have checked all continuity and it is ok the exhaust air is strong and i am getting 230v at the plug but I am just getting very little heat... cant find the problem
  #25 (permalink)
Old 08-13-2012, 07:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Can you describe more detailed what and how did you check?
What is the complete model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #26 (permalink)
Old 08-13-2012, 10:18 PM
Junior Member
Default Gene
i placed the revised information in the next post
  #27 (permalink)
Old 08-13-2012, 10:30 PM
Junior Member
Default
I dont know where to find the model number It is a whirpool gold I have tried everything I
pulled it appart to pieces and checked every thermostat and fuse available the ones on the
blower fan casing and the ones on the heating element casing i disconected both wires on
each fuse, thermostat, and element and tested for continuity with a multimeter I checked
for any signs of loose wires on the motor I also washed any areas where lint was starting to
build up and I pulled it away from the wall thinking maybe it was the exhaust but no luck,
today I rebuilt it and tested plugged in and it looks like the heating element is not turning
bright red but there is some heat another thing I noticed whenever you touch the dryer
bbarefoot it will shock you, I placed an external ground line to the external ground
connector in the back goind to a ground rod but it still gives a shock when you touch it
barefoot
Read more: Frigidaire Dryer Has No Heat
http://forum.appliancepartspros.com
  #28 (permalink)
Old 08-14-2012, 02:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the wires from the heating element terminals and check for continuity between each of the terminals and the ground.
The name plate is usually located on the dryer door frame.
__________________
  #29 (permalink)
Old 02-01-2013, 09:49 AM
Junior Member
Default
Hi lexmp, replacing the motor did solve my problem. When I replaced the motor, I did find some of the contacts severely burned and to rewire them. This was probably the root cause of the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire gas dryer no heat snobgnol Dryer Repair 1 01-24-2011 06:52 PM
Frigidaire Dryer that won't heat huha69 Dryer Repair 7 10-18-2010 09:21 AM
Frigidaire Gas Dryer No Heat mtsolutions Dryer Repair 12 05-24-2010 09:45 PM
No Heat in Frigidaire dryer mzakal Dryer Repair 1 04-12-2010 06:04 AM
Frigidaire dryer won't heat MotormanMarc Dryer Repair 1 06-29-2009 01:08 PM
