Discuss
Frigidaire Dryer Has No Heat
 in
Dryer Repair
Read the diagram how to check the timer contacts and also check the resistors value at the timer. Unfortunately I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Dryer Has No Heat
  #11 (permalink)
Old 05-29-2012, 12:50 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Unfortunately I can't find the diagram anywhere.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 05-29-2012, 01:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the dryer. Disconnect the wires from the heater. Make sure they are not touching any other wires and/or any metal parts.
Plug the dryer and start it. Measure the voltage between each of the wires and the ground. Post the results.
It might help a lot if you can post the wiring diagram.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 06-13-2012, 08:00 PM
Junior Member
moody9207 is on a distinguished road
Default
Hi Gene & Simon, finally was able to get to my daughter's house and check out the voltage at the two wires on the heating element. Between ground and the yellow ones there was no voltage, between ground and the black one there was 120V, both while the dryer was running on the heat cycle.
I also found the wiring diagram and it is attached as pdf file. For the two yellow wires going to the heating element, one comes from the motor and the other comes from the timer.
  #14 (permalink)
Old 06-14-2012, 10:35 AM
Expert
Default
Hi.
According the diagram the contacts at the motor switch M2 - M3 doesn't close. You need to replace the motor.
The motor Part number: 5303283470
Thank you.
Simon.
__________________
  #15 (permalink)
Old 06-23-2012, 04:45 PM
Junior Member
Default
Hi Simon, from the diagram I can see that conclusion. I have two additional questions - 1st, is it feasible to repair these contacts rather than replace the motor, and 2nd, is the replacement motor newer than the 19 year old dryer, i.e., has this motor been used in subsequent model years?
  #16 (permalink)
Old 06-24-2012, 07:23 PM
Expert
Default
Hi.
You can always try to fix it but the statistics are against you.
And yes - this is most likely very common motor. But you should check it by the model number.
Thank you.
Simon.
__________________
  #17 (permalink)
Old 07-10-2012, 07:12 AM
Junior Member
Default
Hi, I have another motor and before I begin the replacement, I just wanted to know if there are any special tools or techniques required to complete this job.
  #18 (permalink)
Old 07-10-2012, 01:41 PM
Expert
Default
Hi.
I don't think you need any special tools to replace the motor.
Good luck.
Simon.
__________________
  #19 (permalink)
Old 07-13-2012, 08:22 PM
Junior Member
Default
Thanks, Simon. I started to take the motor out. The electric connector is burned on the yellow and black wires and now I wonder if this has been the problem and not the motor itself. Can I get this connector? Can I simply splice it into the existing wiring? What would cause this burning? Could this have led to a serious house fire?
If I do need to replace the motor, how do I remove it from the cage? I don't see an easy way to do this.
  #20 (permalink)
Old 07-14-2012, 07:53 PM
Junior Member
Default
I wanted to say that I also see some burning at the connection to the heating element. See attached pic.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire gas dryer no heat snobgnol Dryer Repair 1 01-24-2011 06:52 PM
Frigidaire Dryer that won't heat huha69 Dryer Repair 7 10-18-2010 09:21 AM
Frigidaire Gas Dryer No Heat mtsolutions Dryer Repair 12 05-24-2010 09:45 PM
No Heat in Frigidaire dryer mzakal Dryer Repair 1 04-12-2010 06:04 AM
Frigidaire dryer won't heat MotormanMarc Dryer Repair 1 06-29-2009 01:08 PM
