| » Dryer runs but does not heat |
Model Number: 110.62512100 Brand: Kenmore Age: 5 - 10 years
My dryer runs but does not heat. I'm military and it's been in storage for 3 years. Just got it out and it does not heat.
I am assuming that the dryer runs in all cycles, but that the heating coil just does not heat up.
It can be the coil, but let's check it out so you order only the right parts. You will need an electrical test meter or better yet, a friend with one who will come over and do this for you. First, with the machine plugged in, make sure you are getting 120v to each side of the connection block. Then unplug the machine and test the thermostats and thermal fuse for continuity. Finally, test the heating coil for continuity and resistance, should be between 10 and 20 ohms. One of these should solve your problem, and thanks for serving.
__________________
| Display Modes | |
| Dryer runs, but no heat | bluky | Dryer Repair | 1 | 12-21-2009 02:36 AM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| dryer runs no heat | Jim Bags | Dryer Repair | 1 | 09-01-2009 05:23 AM |
| Gas dryer runs but won't heat | sblack | Dryer Repair | 1 | 10-07-2008 02:41 AM |
| Dryer runs no heat | glennb | Dryer Repair | 1 | 08-10-2007 10:24 AM |
