Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Bosch Nexxt 500Plus Series - Dryer issues with starting (http://forum.appliancepartspros.com/dryer-repair/470154-bosch-nexxt-500plus-series-dryer-issues-starting.html)
BoraTasic 04-21-2012 03:32 PM
We've had this dryer for some time now and over the past six months or so we have had issues about every 3-4 times we run it, it would not start.
When clothes are put in, and the switch knob is turned to the desired setting, nothing happens (there is no "time remaining" light, or any sort of error or indicator, nor does anything happen when start button is pushed). In most cases if we let it sit around for a while (30 minutes or so later) the lights would come on and it would start fine. We can even dry multiple loads and it works ok.
I wonder if anyone has (had) the same problem or if anyone has the solution to it.
Thanks.:confused:
