With the drum belt taken off, the dryer motor starts, makes a lot of vibration like noise and stops. Motor is hot to touch after it stops. The motor will start again after it cools down. There is no decernable end play or radial play on motor shaft at either end. Also, motor turns freely and smoothly by hand.
Replaced motor as suggested. Symptoms remain exactly as before. =========================================== Solution: When my contractor was refinishing the garage he wired the NMEA 14-30R plug socket incorrectly. UGH!!!
Groups: APP Team
Hi. I'm afraid, you are looking at the motor replacement. Most likely the bearing are gone. The motor Part number: W10410996
Originally Posted by: Simon / APP Team Hi. I'm afraid, you are looking at the motor replacement. Most likely the bearing are gone. The motor Part number: W10410996
=========================== Replaced motor as suggested. This did not resolve the problem. Symptoms remain the same.
Groups: APP Team
Hi.
Check if the motor getting 120VAc. Check the voltage drop.
Thank you.
Simon.
