Rank:: Member
Kenmore dryer will start but quites after approx 10 minutes and will not star again until 30-40 minutes have passed.
What is the complete model number of the dryer?
Rank:: Member
Model 110 66912691
Latch is good, timer is good, element is good. Drum turn, there does seem some resistance or maybe I'm just getting weaker.
Sounds like the problem is a bad motor. It overheats and the overload protector turns it off until it cools down. - The motor Part number: 279787
