our dryer won't heat. it works well except the the heat. any idea why? really appreciate your help. thank you
Can you see the igniter come on?
I will check it when I get home.
the ignitor doesn't come on. We also cleaned to make sure nothing clogged. any suggestion ? really appreciate your help
If the ignitor don't come on it could be a bad ignitor or thermal fuse.
The thermal fuse could be checked for continuity with a multimeter.
I checked the again the ignitor and found out that it cracked, I ordered a new one and just replaced it. It works again. So happy ! Thank you so much for the guide/instruction
