Discuss
Maytag MLE2000AYW dryer heating problem
 in
Dryer Repair
So far your web site has helped me with my attempts to fix our Maytag MLE2000AYW stackable washer dryer but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag MLE2000AYW dryer heating problem
  #1 (permalink)
Old 09-04-2009, 05:56 AM
Junior Member
jgram is on a distinguished road
Default Maytag MLE2000AYW dryer heating problem
Brand: Maytag   Age: 5 - 10 years
So far your web site has helped me with my attempts to fix our Maytag MLE2000AYW stackable washer dryer but I have a few questions. The drum does go around and I pulled the heating assembly and it showed good or (0) for the fuse, low thermastat, High thermastat, and 11 resistance for the heating coil. I put it back together and it worked (So I thought). The wife used it this morning and it did not heat. I put the timer on the setting I tested it yesterday and it still worked (the more/Less dry area of the timer) but at the normal time digit area and perm press it does not heat. Could it be the timer? or should I be looking for somethinng else?
I checked the braker, checked the electric posts where the plug wires in and I checked for obstructions in the venting as well. All good.
Any help to narrow the search would be of a great help so that I do not order the wrong parts. You have saved me from ordering a heating assembly so far.
Greg Jenswold
Ads By Google
  #2 (permalink)
Old 09-04-2009, 01:38 PM
Junior Member
Default
sorry wrong post
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Heating Problem davisroy Dryer Repair 3 11-13-2009 03:57 PM
Problem with Maytag oven heating up after replacing part sblank3 Oven Repair (including Ranges and Cooktops) 8 02-18-2009 05:46 PM
Dryer Heating Problem John S Dryer Repair 0 03-06-2008 02:40 PM
Gas Dryer Heating Problem RARMSTRONG@ADELPHIA.NET Dryer Repair 1 12-10-2007 12:19 PM
gas dryer heating problem sakks Dryer Repair 1 09-14-2007 05:45 AM
