Discuss
Noisy Maytag Dryer LDE8500ACW
 in
Dryer Repair
My 14 yr old Maytag Dryer LDE8500ACW is making a lot of noise (metal screeching noise). Sometimes it starts with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Noisy Maytag Dryer LDE8500ACW
  #1 (permalink)
Old 01-21-2008, 05:52 PM
Junior Member
Helpmefix is on a distinguished road
Default Noisy Maytag Dryer LDE8500ACW
Model Number: LDE8500ACW   Brand: Maytag   Age: More than 10 years
My 14 yr old Maytag Dryer LDE8500ACW is making a lot of noise (metal screeching noise). Sometimes it starts with almost no noise, then it becomes almost constant and it sometimes goes away. When I removed the front panel and turned the dryer on, it made no noise so I could not tell were the noise was coming from. After I put it back together and used the dryer with clothes in it the noise returned.
I reviewed a post for a different Maytag model and it hinted at replacing the bearing kit, drum roller, belt and idler pulley. So I took off the front of the dryer and the lower right access panel to look around and vacuum the inside clean. The belt is significantly worn so that needs to be replaced.
1) Does it make sense to replace the other parts listed above?
2) I looked around to try to figure out how to replace the belt, but not sure what to do. Do I remove the "tumbler front" and then gain access that way. Any helpful hints would be greatly appreciated.
Thanks,
Sal
Ads By Google
Related Models
Maytag LDE8500ACW DRYER- ELE
Maytag LDE8506ACE DRYER- ELE
Maytag LDE8506ACM DRYER- ELE
Maytag LDE8506ADE DRYER- ELE
Maytag LDE8600 DRYER- ELE
Maytag LDE8600ACL DRYER- ELE
Maytag LDE8600ACW DRYER- ELE
Maytag LDE8600ADL DRYER- ELE
Maytag LDE8600ADW DRYER- ELE
Maytag LDE8604ACE DRYER- ELE
Maytag LDE8604ACL DRYER- ELE
Maytag LDE8604ACM DRYER- ELE
Maytag LDE8604ADE DRYER- ELE
Maytag LDE8604ADL DRYER- ELE
Maytag LDE8604ADM DRYER- ELE
Maytag LDE8606ACE DRYER- ELE
Maytag LDE8606ACM DRYER- ELE
Maytag LDE8606ADE DRYER- ELE
Maytag LDE8616ACE DRYER- ELE
Maytag LDE8616ACM DRYER- ELE
Maytag LDE8624ACE DRYER- ELE
Maytag LDE8624ACL DRYER- ELE
Maytag LDE8624ACM DRYER- ELE
Maytag LDE8624ADE DRYER- ELE
Maytag LDE8626ACE DRYER- ELE
Maytag LDE8626ACM DRYER- ELE
Maytag LDE8626ADE DRYER- ELE
Maytag LDE8704ACE DRYER- ELE
Maytag LDE8704ACL DRYER- ELE
Maytag LDE8704ACM DRYER- ELE
Maytag LDE8706ACE DRYER- ELE
Maytag LDE8706ACM DRYER- ELE
Maytag LDE8706ADE DRYER- ELE
Maytag LDE8804ACE DRYER- ELE
Maytag LDE8804ACL DRYER- ELE
Maytag LDE8804ACM DRYER- ELE
Maytag LDE8804ADE DRYER- ELE
Maytag LDE882 DRYER- ELE
Maytag LDE8824ACE DRYER- ELE
Maytag LDE8824ACL DRYER- ELE
Maytag LDE8824ACM DRYER- ELE
Maytag LDE8824ADE DRYER- ELE
Maytag LDE8904ACE DRYER- ELE
Maytag LDE8904ACL DRYER- ELE
Maytag LDE8904ACM DRYER- ELE
Norge LDE9127A DRYER- ELE
Norge LDE9127H DRYER- ELE
Norge LDE9127W DRYER- ELE
Maytag LDE9206ACE DRYER- ELE
Maytag LDE9206ACM DRYER- ELE
Maytag LDE9206ADE DRYER- ELE
Maytag LDE9304ACE DRYER- ELE
Maytag LDE9304ACL DRYER- ELE
Maytag LDE9304ACM DRYER- ELE
Maytag LDE9304ADE DRYER- ELE
Maytag LDE9304ADL DRYER- ELE
Maytag LDE9304ADM DRYER- ELE
Maytag LDE9304AEE DRYER- ELE
Maytag LDE9306ACE DRYER- ELE
Maytag LDE9306ACM DRYER- ELE
Maytag LDE9306ADE DRYER- ELE
Maytag LDE9306ADM DRYER- ELE
Maytag LDE9306AEE DRYER- ELE
Maytag LDE9314ACE DRYER- ELE
Maytag LDE9314ACL DRYER- ELE
Maytag LDE9314ACM DRYER- ELE
Maytag LDE9314ADE DRYER- ELE
Maytag LDE9316ACE DRYER- ELE
Maytag LDE9316ACM DRYER- ELE
Maytag LDE9316ADE DRYER- ELE
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
  #2 (permalink)
Old 12-01-2010, 11:53 AM
Junior Member
rick-dallas is on a distinguished road
Default
Hey Sal,
I realize your post is a bit dated but was wondering what you ended up doing to fix your dryer?
I have the same model and from your description, the same exact problem. Just curious what you did to fix it.
Trying to learn from other people's experience....
Thanks!
Rick
  #3 (permalink)
Old 12-01-2010, 05:07 PM
Junior Member
Default
Rick,
Luckily I am a pack-rat with emails so I was able to piece together what I did...
I started with ordering these parts:
Part Number Description Qty Price
AP3988821 (Y312959) BELT, TUMBLER & MOTOR 1 $19.31
AP3992607 (Y312527) WASHER, IDLER SHAFT ( 2 $3.31
AP3970789 (Y303705) PULLEY, IDLER 1 $10.34
AP2996314 (354987) Ring - e 1 $4.36
But the noise must have persisted because I ordered these a couple weeks later:
AP204721 (12001541) Drum roller 1 $18.01
AP3038076 (9703438) Retaining clip 1 $5.35
I vaguely remember that the black part of the drum roller separated from the "rim" of the roller and that was the cause of the noise. I would recommend doing both the drum roller & belt. I get the little clips because inevitably I might damage one & it is cheap enough.
And then a year later a totally different problem started and I replaced:
AP2954258 (312967) Clamp 1 $3.78
AP4294048 (Y303836) BLOWER WHEEL ASSEMBLY 1 $21.46
This was obvious because the center plastic sleeve started to deteriorate and the blades were scrapping on the inside of the Blower Housing.
Hope this helps & Good Luck,
Sal
  #4 (permalink)
Old 12-01-2010, 08:23 PM
Junior Member
Default
Sal,
Thanks so much for your quick and thorough response. I am taking your suggestion and ordering the parts you recommended and see how it goes from there.
Again, I appreciate the timely response? Isn't the internet great!
__________________
Rick Moore
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy Maytag Dryer Mattyony Dryer Repair 1 02-22-2010 12:45 PM
Very Noisy Maytag Gas Dryer achellb Dryer Repair 1 07-07-2009 12:56 PM
Noisy Maytag Gas Dryer jenniferleigh Dryer Repair 6 07-06-2009 09:09 AM
Noisy Maytag Dryer jkolk Dryer Repair 11 01-27-2009 02:04 PM
Noisy start on Maytag Gas dryer Stickman Dryer Repair 0 11-25-2007 09:19 AM
