Discuss
Noisy Maytag Dryer LDE8500ACW
 in
Dryer Repair
My 14 yr old Maytag Dryer LDE8500ACW is making a lot of noise (metal screeching noise). Sometimes it starts with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Noisy Maytag Dryer LDE8500ACW
  #1 (permalink)
Old 01-21-2008, 06:52 PM
Helpmefix Helpmefix is offline
Junior Member
Helpmefix is on a distinguished road
Default Noisy Maytag Dryer LDE8500ACW
Model Number: LDE8500ACW   Brand: Maytag   Age: More than 10 years
My 14 yr old Maytag Dryer LDE8500ACW is making a lot of noise (metal screeching noise). Sometimes it starts with almost no noise, then it becomes almost constant and it sometimes goes away. When I removed the front panel and turned the dryer on, it made no noise so I could not tell were the noise was coming from. After I put it back together and used the dryer with clothes in it the noise returned.
I reviewed a post for a different Maytag model and it hinted at replacing the bearing kit, drum roller, belt and idler pulley. So I took off the front of the dryer and the lower right access panel to look around and vacuum the inside clean. The belt is significantly worn so that needs to be replaced.
1) Does it make sense to replace the other parts listed above?
2) I looked around to try to figure out how to replace the belt, but not sure what to do. Do I remove the "tumbler front" and then gain access that way. Any helpful hints would be greatly appreciated.
Thanks,
Sal
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Truly Noisy But Working Fine? frankco5 Dryer Repair 1 05-22-2008 06:51 AM
Noisy start on Maytag Gas dryer Stickman Dryer Repair 0 11-25-2007 10:19 AM
vrey noisy dryer very noisy dryer Dryer Repair 0 10-27-2007 11:09 PM
noisy dryer when on ellashoe Dryer Repair 1 10-22-2007 04:45 AM
Noisy Maytag DW Rocky Chiquera Dishwasher Repair 2 07-27-2007 08:08 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
