Hello,
I purchased a used GE Prodigy Dryer and after only a week the heating elements burned out. I started disassembly, this model was rather difficult, and begin taking it apart so that I could clean it. There was no wiring diagram inside the control panel. Anyway, I reassembled it to find it not wanting to start. I can here the timer clicking. To be honest I'm not a hundred percent sure I rewired it correctly. I put labels on them all but some of them fell off. I have checked for continuity on the dryer switch and all the fuses and everything is Ohming out right. I'm also getting 250v into the unit. Any ideas? Also does anyone have a wiring diagram for this puppy? I would appricate any help that can be offered.
