AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't start after replacing drum rollers
This is a follow-up question. I replaced the drum support rollers and got the dryer back together. But now it won’t start (yes, I have it plugged in, and I have the yellow and blue wires connected correctly to the door switch). The expert answer I received was: “You will need to disassemble the unit and see if any of the wires going to the motor, or thermal fuse have come loose. If not, you will need to test the door switch and see if it is bad and replace it if needed. You can test this with a multi-meterAP3873826.” I checked the wires and didn’t see anything lose. I bought the digital multi-meter and read your online instructions but can’t figure out how to use it. The instructions with the meter have the following options: - DC Voltage Measurement - DC Current Measurement - AC Voltage Measurement - Resistance Measurement - Diode Test - Battery & Fuse Replacement
First, how do I test the door switch? Which of the above directions to I use?
What else do I test and how specifically do I do it? For example, the meter has a dial number numbers (2, 20, 200, 600, etc.); what number do I set it on to test the various components? What do I touch the black and red wire probes to? How do I interpret the reading in the window.
This should not be difficult. I just need specific, clear instructions on how do to it.
Dryer Repair
