Discuss
Dryer automatically turns on before hitting start, will this be a saftey issue?
 in
Dryer Repair
Okay, so my dryer stopped drying, figured out it was the heating element fuse. I fixed that, but now now
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer automatically turns on before hitting start, will this be a saftey issue?
  #1 (permalink)
Old 04-14-2012, 08:16 AM
Junior Member
ACardAttack is on a distinguished road
Default Dryer automatically turns on before hitting start, will this be a saftey issue?
Brand: Whirlpool   Age: 1 - 5 years
Okay, so my dryer stopped drying, figured out it was the heating element fuse. I fixed that, but now now that if my dryer dial is not set to off, the dryer will start even if I dont hit "start", if it is on "off" it wont run, but the second I move the dial to how long I want it to dry, the dryer starts.
Is this a major problem I need to worry about or can I just forget about it? If I should fix it, what likely is it? I looked at the starter switch, but it seemed fine and I didnt even touch it when I switched out the fuse.
Ads By Google
  #2 (permalink)
Old 04-15-2012, 07:09 PM
Junior Member
Nvious1 is on a distinguished road
Default
Sorry I can't provide any meaningful support but I have the same issue with my GE dryer. I haven't seen a response on my thread either so hopefully you have better luck.
  #3 (permalink)
Old 04-16-2012, 03:04 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
ACardAttack
A model number may help others help you.
Model Number Locator
Nvious1
A model number may not help you as GE likes to keep all technical info a big secret.
I do not have access to that info so hopefully someone else with info on your unit will jump in.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer ran without hitting start/now does not run at all paul2713 Dryer Repair 0 02-19-2011 05:28 AM
GE dryer will not start automatically when door is closed camalone2 Dryer Repair 0 03-21-2010 01:44 PM
Microwave Turns on automatically foxx_ Microwave Repair 0 08-23-2009 03:19 AM
Dryer Turns on Without Hitting "Start" marcy15209 Dryer Repair 2 06-24-2009 05:09 PM
Something hitting the drum when it turns janjan Washer Repair 2 10-05-2007 03:49 PM
