Rogscott
#1 Posted : Friday, April 13, 2012 4:34:09 PM(UTC)
Rogscott
Hey guys, I'm having trouble with my dryer...it won't start haha. I've replaced the power cord, removed and tested the thermal fuse, starter switch, door switch and thermostat. The motor is not making any humming or screeching noise but pulled it anyways and brought it to a shop. They said there was nothing wrong with the motor without testing it. I went home, put everything back together and I still have a non-working dryer thats about 2 years old. Can anybody help me figure this out??
#2 Posted : Saturday, April 14, 2012 2:27:19 AM(UTC)
Replacement parts for Maytag AED4475TQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
You said that you had tested certain parts but did not say how so:
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
First check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK
Unplug the unit and attach (tape) one meter lead to L1 at the power cord and leave it there.
Set the unit to timed dry mid scale.
Set the meter to a low ohms scale,usually 200 ohms.
Now work your way back through the units start circuit.
So Fist measurement should be the timer connector BK = 0 ohms.
Then
Timer connector BU = 0 ohms
Thermal fuse both sides = 0 ohms
4M on the motor = 0 ohms
W or W-R on the push to start = approximately 1.5 ohms
Activate the push to start when doing the following.
BK on the push to start = 1.5 ohms approx.
Door switch NO connector = 1.5 ohms
Door closed
Door switch NC connector = 1.5 ohms approx.
N on the power cord = 1.5 ohms.
File Attachment(s):
AED4475.pdf (507kb) downloaded 7 time(s).
Rogscott
#3 Posted : Sunday, April 15, 2012 6:21:36 PM(UTC)
Rogscott
Thank you for your help on this matter Denman. I started from the begining testing the outlet. I had trouble finding a spot to get a reading but eventually I did. Then I tested the the new power cord to the power strip. I got a reading of around 120 between L1 and L2, about the same for N to L1. When I tested N and L2 I got no reading at all. Would this mean my wall outlet is bad?
#4 Posted : Monday, April 16, 2012 1:05:34 AM(UTC)
Yes it could be a bad wall outlet.
Could be the outlet itself or where the wiring attaches to it.
Could also be that one of the circuit breakers are bad.
And on very, very rare occasions the wire from the circuit breaker to the outlet
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by Matt18 11/26/2013 9:56:49 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
