Discuss
Fisher Paykel Dryer no heat
 in
Dryer Repair
There is no heat for all settings, auto or manual, regular or denim. The exhaust air flow is strong, but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Fisher Paykel Dryer no heat
  #1 (permalink)
Old 09-01-2009, 10:19 PM
Junior Member
stevejac is on a distinguished road
Default Fisher Paykel Dryer no heat
Model Number: DEGX1   Brand: -other-   Age: 1 - 5 years
There is no heat for all settings, auto or manual, regular or denim. The exhaust air flow is strong, but cold. Thanks Stevejac
Related Models
Amana DEI-512 RANGE- S/C S/I DDRAFT GAS
Amana DEI-522 RANGE- S/C S/I DDRAFT GAS
Amana DEI-522C RANGE- S/C S/I DDRAFT GAS
Frigidaire DEIDH1 Frg(v8) / Gas and Electric Dryers
Frigidaire DEIDL1 Frg(v9) / Gas and Electric Dryers
Frigidaire DEIDW1 Frg(v7) / Gas and Electric Dryers
Frigidaire DEIFL0 Frg(v2) / Electric Dryer
Frigidaire DEIFW0 Frg(v1) / Electric Dryer
Frigidaire DEILL1 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILL3 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL4 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DEILW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW4 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW5 Frg(v1) / 27 " Electric Dryer
Frigidaire DEISFL0 Frg(v4) / Electric Dryer
Frigidaire DEISFL1 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFL3 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL4 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL5 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFW0 Frg(v3) / Electric Dryer
Frigidaire DEISFW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFW3 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW4 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW5 Frg(v3) / 27 " Electric Dryer
Norge DEJ208A DRYER- ELE
Norge DEJ208H DRYER- ELE
Norge DEJ208W DRYER- ELE
Norge DEJ254A DRYER- ELE
Norge DEJ254H DRYER- ELE
Norge DEJ254W DRYER- ELE
Norge DEJ264A DRYER- ELE
Norge DEJ264H DRYER- ELE
Norge DEJ264W DRYER- ELE
Norge DEK201AC DRYER- ELE
Norge DEK201WC DRYER- ELE
Norge DEK204AC DRYER- ELE
Norge DEK204HC DRYER- ELE
Norge DEK204WC DRYER- ELE
Menu Master DEL10D COMMERCIAL MICROWAVES
Menu Master DEL10E COMMERCIAL MICROWAVES
Norge DEL202A DRYER- ELE
Norge DEL202H DRYER- ELE
Norge DEL202W DRYER- ELE
Norge DEL202WC DRYER- ELE
Norge DEL203A DRYER- ELE
Norge DEL203AC DRYER- ELE
Norge DEL203H DRYER- ELE
Norge DEL203HC DRYER- ELE
Norge DEL203W DRYER- ELE
Norge DEL203WC DRYER- ELE
Norge DEL204A DRYER- ELE
Norge DEL204H DRYER- ELE
Norge DEL204W DRYER- ELE
Norge DEL253A DRYER- ELE
Norge DEL253H DRYER- ELE
Norge DEL253W DRYER- ELE
Norge DEL263A DRYER- ELE
Norge DEL263H DRYER- ELE
Norge DEL263W DRYER- ELE
Norge DEM202A DRYER- ELE
Norge DEM202AC DRYER- ELE
Norge DEM202H DRYER- ELE
Norge DEM202HC DRYER- ELE
Norge DEM202W DRYER- ELE
Norge DEM202WC DRYER- ELE
Norge DEM204 DRYER- ELE
Norge DEM204 REV A DRYER- ELE
Norge DEM204 REV B DRYER- ELE
Norge DEM204 REV C DRYER- ELE
Norge DEM204A DRYER- ELE
Norge DEM204AC DRYER- ELE
Norge DEM204H DRYER- ELE
Norge DEM204HC DRYER- ELE
Norge DEM204W DRYER- ELE
Norge DEM204WC DRYER- ELE
Norge DEM205A DRYER- ELE
Norge DEM205AC DRYER- ELE
Norge DEM205W DRYER- ELE
Norge DEM205WC DRYER- ELE
Norge DEN202A DRYER- ELE
Norge DEN202AC DRYER- ELE
Norge DEN202W DRYER- ELE
Norge DEN202WC DRYER- ELE
Norge DEN203A DRYER- ELE
Norge DEN203AC DRYER- ELE
Norge DEN203W DRYER- ELE
Norge DEN203WC DRYER- ELE
Norge DEN204A DRYER- ELE
Norge DEN204GV DRYER- ELE
Norge DEN204KA DRYER- ELE
Norge DEN204KV DRYER- ELE
Norge DEN204V DRYER- ELE
Norge DEN204VC DRYER- ELE
Norge DEN204W DRYER- ELE
Norge DEP222VC DRYER- ELE
Norge DEP223M DRYER- ELE
Norge DEP223V DRYER- ELE
Norge DEP224V DRYER- ELE
Norge DEP224VC DRYER- ELE
Frigidaire DES100CD1 Kel(v2) / Electric Dryer
Frigidaire DES100CW1 Kel(v1) / Electric Dryer
Frigidaire DES100FD2 Kel(v2) / 27 " Dryer
Frigidaire DES100FW2 Kel(v1) / 27 " Dryer
Amana DES11E COMMERCIAL MICROWAVES
Menu Master DES11EA COMMERCIAL MICROWAVES
Frigidaire DESFL0 Frg(v6) / Electric Dryer
Frigidaire DESFL1 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFL3 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL4 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFW0 Frg(v5) / Electric Dryer
Frigidaire DESFW1 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW2 Frg(v3) / 27 " Electric Dryer
  #2 (permalink)
Old 09-04-2009, 11:41 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Sorry Steve but this is not a brand that I think we are qualified to comment on.
Try several other Forums and see if you can get some help.
Good luck.
__________________
  #3 (permalink)
Old 10-10-2009, 09:51 AM
Junior Member
JohnnyB12 is on a distinguished road
Stevejac - Could be easy fix. I have same model. The easy way is to get help, lift the front of the dryer high enough to get your hand up under the front of the dryer, and feel for a hi -temp re-set button inside the front panel area (BE CAREFUL, lot's of sharp edges so use caution or you'll slice your hand...BAD). On the right side of the dryer on the inside where you can get your hand in, feel around and you should find a hi-temp reset button that's faces out towrds the front horizontally (not a big button). Press that button and you'll hear a slight "click". That will re-set the hi-temp control. While you're at it, remove the lint collector on the inside of the drum and clean really well around the wiring. Lint tends to build up inside this and it should be cleaned regularly. If you want to be safer and not risk a cut to the hand, lift the dryer lid and remove the two white rubber/plastic screw caps at the front edges. Remove the two screws at the front of the lid. The lid should then just lift up and back (be careful to handle carefully so as not to break lid plastic in process). Then you should see two red clips at each side of the front metal front panels. Pop those and then lift the front panel from the machines "feet" at the front (AGAIN, careful as the rough metal edges are sharp and there is a ground wire attached to the front. Best to get someone to hold that front panel so you don't have to add extra steps to re-attach the ground wire). From here, you'll easily see the hi-temp reset button, press it, listen for the "click" and then put everything back together in reverse order.
In the end, you'll need to watch it as there could be issues with the heating element which is known to burn out over time.
Again, I'm not an expert. Just another owner of the same unit who had the same problem and fixed it with with a little help from the web :-)
Good Luck
J
  #4 (permalink)
Old 09-04-2010, 03:06 PM
Junior Member
dragonmeister is on a distinguished road
Default
JohnnyB12's description got it right on the money.
In my opinion, taking the front panel off is the way to go. Take the extra step and disconnect the ground wire so you can completely remove the front panel. Not only does it allow easy access to the reset button, but also allows you to vacuum all of the lint that accumulated inside. And was there a bunch of it. Just remember to reattach the ground wire before reattaching the front panel.
  #5 (permalink)
Old 12-26-2011, 01:10 PM
Junior Member
Godprazr is on a distinguished road
Smile
Thanks JohnnyB12!!!
I had the same problem. I think mine has a different model number, its a "Smartload" . But I found a small round re-set button at the place you described, and in a matter of minutes, problem solved!!
  #6 (permalink)
Old 12-03-2013, 06:23 PM
Junior Member
crom is on a distinguished road
Smile thanks johnnyb12
You're a genius dude. Saved me a pile of cash on this repair!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fisher paykel squeaky dryer lisarobinson@hotmail.com Dryer Repair 16 06-26-2012 07:53 AM
Fisher & Paykel Dishwasher jok3rw Dishwasher Repair 1 03-02-2011 11:05 PM
Fisher & Paykel Dryer redsuspender Dryer Repair 2 07-07-2009 06:49 PM
now power on fisher paykel steve rogers Washer Repair 1 03-31-2009 06:53 PM
Fisher&Paykel parts help campiej Oven Repair (including Ranges and Cooktops) 1 11-24-2008 01:54 PM
