I had changed the ignitor it still will not light test the thermistat fuse with ohm and it reads 1. nothing would this stop the ignitor from working
Groups: APP Team
Hi. You will nave to use the multimeter to perform the continuity tests. With power off and one wire off check for continuity at : Flame sensor - continuity less then 1ohm, thermal fuse, cycling thermostat, hi-limit thermostat, cut-off thermal fuse. Determine which one is open and replace it. The flame sensor Part number: AP2910747
thank you for the help it is the thermal fuse
Groups: APP Team
Hi.
I'm glad we solved this problem.
Simon.
