| » Not the heating element |
Model Number: ned5240tq0 Brand: Amana Age: 1 - 5 years
My timer stopped moving, and the dryer wouldn't shut off. There is also no heat.
I did some googling, and the heating element was indicated. I scrounged through the husbands tool box, took it off and the local appliance parts place tested it, and said it is fine. Any other suggestions? Ads By Google Related Models Last edited by Kayhold : 04-12-2012 at 08:50 AM. |
Hi.
Did you try both timed and auto cycles? When you advance the timer to the end of the cycle will the dryer stop? Do you feel OK to perform the "life" test using the multimeter? Please, post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
In this unit both the heater and the timer motor run off of 240 volts so if the unit does not advance in both auto and timed dry I would do the following.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!!
__________________
| Display Modes | |
| heating element not heating during wash cycle | wiz | Dishwasher Repair | 3 | 02-21-2011 11:25 AM |
| Heating coil or Heating element assembly | jayclagg | Dryer Repair | 1 | 02-11-2010 07:26 AM |
| Heating Element On/Off buttons don't work. Element stays on mostly. | juliotamu01 | Dishwasher Repair | 0 | 11-13-2009 06:05 AM |
| Replaced heating element now heating element nor broil element work, all else does | rontetley | Oven Repair (including Ranges and Cooktops) | 1 | 10-26-2009 01:30 PM |
| bake element not heating but broil element heating okay | horno | Oven Repair (including Ranges and Cooktops) | 1 | 10-04-2009 11:37 AM |
