| » Dryer Motor Wiring? |
Post a pic of it, And I could be sure.
Thanks for replying.
I don't have a picture of it right now but, it looks just like the one on the lower right in this craigslist posting. I removed the fan part when I took it out but the base and frame are the same. I'm not sure if this site allows hyperlinks so, I pasted the address with "zz" where "tt" normally would go. Just change it once you've copied it to your address bar. hzzp://detroit.craigslist.org/wyn/tls/1324131697.html |
Dude I am old but I ain't that old
Yup, I'd seen that method before. Someone also wires up several light bulbs in series as a load. It's a clever way of saving your stuff.
I went ahead and opened the motor. Once I'd done that, everything became much more clear and I was able to figure out which wires went to which winding. After reassembling the motor, I hooked it up to line voltage and jumping the lead to the start circuit only produced a loud hum. The motor shaft visibly shifted about 1/16 of an inch but would not rev. I tried revving it by hand while it had power but it would not start and was quite difficult even make it move. I decided to just wire the run circuit direct. I was able to make it run this way by gently twisting the shaft when powered but it took too long to get up to speed and it got quite warm. I think it's a lost cause. Now, I'm moving on to trying out a washer motor I have for the same purpose. The dryer motor is simpler but now out of necessity, I'll try the washer one instead. For this one, I do have picture so, hopefully, it'll be something I can get help with. I'll post about the washer motor to a thread on the washer forum. Thanks for your help. |
It just might be that the motor was poling out. Bad bearings. yeah post that pic.
Quote:
I found this diagram online and using it, I connected the wires according to the numbers on the motor side. Some of them were not exactly what the diagram had but it proved a good guide. I'll post to the other thread as well. hzzp://www.applianceaid.com/newimages/norge-oldstyle-washer.JPG |
| Display Modes | |
| Re-wiring Dryer motor - WE17M22 | k_pbert | Dryer Repair | 1 | 10-03-2009 02:06 PM |
| wiring diagram for GE dryer motor | bigwolve | Dryer Repair | 1 | 04-02-2009 02:06 AM |
| Straight Wiring A Kenmore Dryer Motor | leglesscrow | Dryer Repair | 1 | 01-07-2009 04:04 PM |
| Replacement Of Ge Dryer Motor The Wiring Is Not The Same As Old One How Do I Wire It | feisty63 | Dryer Repair | 1 | 01-07-2009 01:25 PM |
| Wiring a Motor back into Maytag Dryer...HELP! | thnkpink16 | Dryer Repair | 1 | 04-07-2008 02:17 PM |
