Maytag model number: ldg9606aae
Part replaced: thermal switch
Parts checked for continuity (all pass): coils igniter tstat hi limit radiant sensor thermal switch thermostat multi temp
ignitor doesn't glow at all...i don't smell gas Is it the timer? any way to test this part? it's coming in around 80 bucks so i want to make sure. when i set it to timed drying i can hear to tick or buss that it's moving.
hope i provided all the necessary info. any help or comments are appreciated. thanks! Dan
