Discuss
Dryer Runs Only if Start Button Held Down, But No Heat
 in
Dryer Repair
I have a 3 year old Kenmore Elite front loading gas dryer (model 110.74972300) that spins only if the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Runs Only if Start Button Held Down, But No Heat
  #1 (permalink)
Old 01-21-2008, 07:26 AM
Stephen D Stephen D is offline
Junior Member
Stephen D is on a distinguished road
Default Dryer Runs Only if Start Button Held Down, But No Heat
Model Number: 110.74972300   Brand: Kenmore   Age: 1 - 5 years
I have a 3 year old Kenmore Elite front loading gas dryer (model 110.74972300) that spins only if the start button is held down, but doesn't heat up at all. So, we can hold the start button down for a long time, the dryer spins, but doesn't heat up at all. I replaced the motor relay and the heat relay, but this didn't help at all. A relative thinks it may be the electronic control assembly. Any thoughts?
I also had a lot of trouble opening up access to the electronic components. There has got to be a better way than bending the metal on the back of the dryer.
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 02:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Stephen,
The problem with your dryer caused by the control board.
In order to open the control panel, using a putty knife, you have to push in the clip (#34 on the break down diagram) on each side of the control panel, pull it toward yourself and lift it up.
- The part number for the control board is AP4319168
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-21-2008, 08:28 PM
Junior Member
Default Thanks
Thanks a lot. I very much appreciate the advice. And, yes, you were right. I got a new control panel, put it in and the dryer is working just fine now.
Last edited by Stephen D : 01-27-2008 at 08:26 PM. Reason: I have since made the repair...and the advice I got was right.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer Will Not Run W/o Holding In Start Button niggdj@bluemarble.net Dryer Repair 10 01-02-2008 08:45 PM
Buzzer and start button buzzing dryer Dryer Repair 2 12-16-2007 03:08 PM
Hum when start button is pushed LOST Dryer Repair 1 10-01-2007 04:59 PM
Dryer start button Yorba Dryer Repair 1 08-13-2007 06:13 PM
Dryer stops running after letting off the Start button Andy Dryer Repair 10 08-01-2007 10:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
