| » Dryer Runs Only if Start Button Held Down, But No Heat |
Model Number: 110.74972300 Brand: Kenmore Age: 1 - 5 years
I have a 3 year old Kenmore Elite front loading gas dryer (model 110.74972300) that spins only if the start button is held down, but doesn't heat up at all. So, we can hold the start button down for a long time, the dryer spins, but doesn't heat up at all. I replaced the motor relay and the heat relay, but this didn't help at all. A relative thinks it may be the electronic control assembly. Any thoughts?
I also had a lot of trouble opening up access to the electronic components. There has got to be a better way than bending the metal on the back of the dryer. Thanks in advance. |
Hi Stephen,
The problem with your dryer caused by the control board. In order to open the control panel, using a putty knife, you have to push in the clip (#34 on the break down diagram) on each side of the control panel, pull it toward yourself and lift it up. - The part number for the control board is AP4319168 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Thanks a lot. I very much appreciate the advice. And, yes, you were right. I got a new control panel, put it in and the dryer is working just fine now.
Last edited by Stephen D : 01-27-2008 at 08:26 PM. Reason: I have since made the repair...and the advice I got was right. |
| Display Modes | |
| Electric Dryer Will Not Run W/o Holding In Start Button | niggdj@bluemarble.net | Dryer Repair | 10 | 01-02-2008 08:45 PM |
| Buzzer and start button | buzzing dryer | Dryer Repair | 2 | 12-16-2007 03:08 PM |
| Hum when start button is pushed | LOST | Dryer Repair | 1 | 10-01-2007 04:59 PM |
| Dryer start button | Yorba | Dryer Repair | 1 | 08-13-2007 06:13 PM |
| Dryer stops running after letting off the Start button | Andy | Dryer Repair | 10 | 08-01-2007 10:56 PM |
