| » Dryer will not cool down |
Model Number: Ler 5636PO0 Brand: Whirlpool Age: 5 - 10 years
At the end of the cycle, it just stays hot; what do I need to replace. I have the schematic.
I cannot find a P00 are you sure it is not a PQ0.
The following is for a PQ0 Replacement parts for Whirlpool LER5636PQ0 29"ELECTRIC DRYER | AppliancePartsPros.com See the attachment for the tech sheet. It includes a timing diagram. Could be a couple things Place timer at the ends of a cycle when cool down should happen. Unplug the unit. Check the timer contacts BK/R. They should be infinite ohms (open). Be sure to disconnect the wires to one of the connectors when checking it. This prevents you from reading an alternate/parallel circuit path. If OK Remove both wire from the heating coil. Check it with the meter, should be 8 to 12 ohms. Then measure from each heating coil connector to a bare spot on the frame. Both should be infinite ohms. If not then the element is grounded and always on.
__________________
| Display Modes | |
| LG dryer cool down does not go off | Bill151 | Dryer Repair | 0 | 03-31-2012 12:06 PM |
| Dryer does not cool down | renegade_7 | Dryer Repair | 1 | 02-02-2012 08:49 PM |
| Refrigerator warm(not cool) freezer cool (not cold) | Magnum777 | Refrigerator & Freezer Repair | 3 | 12-24-2011 03:40 PM |
| dryer starts cool down too soon | ctcashatt | Dryer Repair | 1 | 10-27-2010 05:33 PM |
| Cool Dryer | Marluc | Dryer Repair | 1 | 09-10-2007 05:46 AM |
