Discuss
Whirlpool stackable washer/dryer set
 in
Dryer Repair
I have recently put on a new belt on the dryer, it seems fine but you can't put a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool stackable washer/dryer set
  #1 (permalink)
Old 01-20-2008, 12:17 PM
emyjoemaxx emyjoemaxx is offline
Junior Member
emyjoemaxx is on a distinguished road
Default Whirlpool stackable washer/dryer set
Model Number: LTE6234AW2   Brand: Whirlpool   Age: 5 - 10 years
I have recently put on a new belt on the dryer, it seems fine but you can't put a heavy load in or the dryer will not run. When it does run with an extremly light load it doesn't run the full course,it will shut off after running for about 10/20min. After it shuts off it doesn't want to start and I have to wait atleast 10/20min maybe longer to even get it to start. I am thinking it could be the motor because when I took it apart there was a lint build up on the motor and through out the dryer. Could it be the motor?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 10:39 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad motor.
- The part number for the motor is AP3094242
Here are the break down diagrams for the Whirlpool laundry center Model LTE6234AW2
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE stackable will not agitate but will spin roger278 Washer Repair 0 01-16-2008 12:10 PM
GE Spacesaver stackable WASHER bookie1959 Dishwasher Repair 0 12-28-2007 04:30 PM
Stackable washer power cord replacement dougstevens Washer Repair 1 12-06-2007 06:00 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
flooding stackable washer anja Washer Repair 1 07-19-2007 06:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
