Discuss
Frigidaire Dryer - No heat!
 in
Dryer Repair
Greetings all, As with most of the posts I have seen, I am also having dryer problems! A few days
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Dryer - No heat!
  #1 (permalink)
Old 08-28-2009, 01:26 PM
Junior Member
jbeaucha is on a distinguished road
Default Frigidaire Dryer - No heat!
Model Number: FGR231AS1   Brand: Frigidaire   Age: 1 - 5 years
Greetings all,
As with most of the posts I have seen, I am also having dryer problems! A few days ago, the dryer began blowing cold air only producing heat within the first few minutes of the cycle then stopping. I checked airflow and made sure the breaker was not kicked. The timer also is not moving and just continues to the cycle for hours on end (I learned the hard way when I went out for a few hours while it ran!). I admit that I'm not too handy when it comes to these things, however, eager minds will get things done and I'm quite determined to fix this. Any help?
Ads By Google
Related Models
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
Whirlpool FGS337GW1
Whirlpool FGS337GW5
Whirlpool FGS337GW6
Whirlpool FGS337GW7
Whirlpool FGS337KN0
Whirlpool FGS337KN1
Whirlpool FGS337KQ0
Whirlpool FGS337KQ1
Whirlpool FGS337KQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS337KW0
Whirlpool FGS337KW1
Whirlpool FGS337KW2 30" Gas Freestanding Self Clean Range
Frigidaire FGS365EBA Frigidaire/gas Range
Frigidaire FGS365EBB Frigidaire/gas Range
Frigidaire FGS365EBC Frigidaire/range
Frigidaire FGS365ECA Frigidaire/gas Range
Frigidaire FGS365ECB Frigidaire/gas Range
Frigidaire FGS365ECC Frigidaire/range
Frigidaire FGS365ECD Frigidaire/range
Frigidaire FGS365ECE Frigidaire/gas Range
Frigidaire FGS365EQA Frigidaire/gas Range
Frigidaire FGS365EQB Frigidaire/gas Range
Frigidaire FGS365EQC Frigidaire/range
Frigidaire FGS365ESA Frigidaire/gas Range
Frigidaire FGS365ESB Frigidaire/gas Range
Frigidaire FGS365ESC Frigidaire/range
Frigidaire FGS366EBA Frigidaire/gas Range
Frigidaire FGS366EBB Frigidaire/gas Range
Frigidaire FGS366EBC Frigidaire/range
Frigidaire FGS366EBD Frigidaire/gas Range
Frigidaire FGS366ECA Frigidaire/gas Range
Frigidaire FGS366ECB Frigidaire/gas Range
Frigidaire FGS366ECC Frigidaire/gas Range
Frigidaire FGS366ECD Frigidaire/gas Range
Frigidaire FGS366EQA Frigidaire/gas Range
Frigidaire FGS366EQB Frigidaire/gas Range
Frigidaire FGS366EQC Frigidaire/range
Frigidaire FGS366EQD Frigidaire/gas Range
Frigidaire FGS366ESA Frigidaire/gas Range
Frigidaire FGS366ESB Frigidaire/gas Range
Frigidaire FGS366ESC Frigidaire/range
Frigidaire FGS366ESD Frigidaire/gas Range
Frigidaire FGS367DBA Frigidaire/gas Range
Frigidaire FGS367DSA Frigidaire/gas Range
Frigidaire FGS367EBA Frigidaire/gas Range
Frigidaire FGS367ECA Frigidaire/gas Range
Frigidaire FGS367ECB Frigidaire/gas Range
Frigidaire FGS367ECC Frigidaire/range
Frigidaire FGS367ESA Frigidaire/gas Range
Frigidaire FGS367FCA Frigidaire/gas Range
Frigidaire FGS367FCB Frigidaire/gas Range
Frigidaire FGS379DBA Frigidaire/gas Range
Frigidaire FGS379DCA Frigidaire/gas Range
Frigidaire FGS379DQA Frigidaire/gas Range
Frigidaire FGS379DSA Frigidaire/gas Range
Frigidaire FGS379EBA Frigidaire/gas Range
Frigidaire FGS379ECB Frigidaire/gas Range
Frigidaire FGS379ECC Frigidaire/gas Range
Frigidaire FGS379EQA Frigidaire/gas Range
Frigidaire FGS379ESA Frigidaire/gas Range
Whirlpool FGS385BL0
Whirlpool FGS385BL1
Whirlpool FGS385BL2
Whirlpool FGS385BL3
Whirlpool FGS385BL4
Whirlpool FGS385BL5
Whirlpool FGS385BQ1
Whirlpool FGS385BQ2
Whirlpool FGS385BQ3
Whirlpool FGS385BW0
Whirlpool FGS385BW1
Whirlpool FGS385BW2
Whirlpool FGS385BW3
Whirlpool FGS385BW4
Whirlpool FGS385BW5
Whirlpool FGS385VL0
Whirlpool FGS385VL1
Whirlpool FGS385VL2
Whirlpool FGS385VW0
Whirlpool FGS385VW1
Whirlpool FGS385VW2
  #2 (permalink)
Old 08-30-2009, 03:29 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Ok, use an electrical meter to test for continuity in the thermostat devices. These are probably not your problem, but check them anyway on the way to looking for the likely problem, your gas burners.
If they check out, your problem is probably in the gas burners. Look at the various posts on this site with gas dryers with heating problems and you will find out what to do.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dryer no heat tshug Dryer Repair 7 01-23-2011 02:16 PM
Frigidaire Dryer that won't heat huha69 Dryer Repair 7 10-18-2010 09:21 AM
Frigidaire dryer turns but no heat MartinF Dryer Repair 3 01-20-2010 06:37 PM
Frigidaire dryer won't heat MotormanMarc Dryer Repair 1 06-29-2009 01:08 PM
frigidaire gas dryer has no heat chevyguy Dryer Repair 0 03-01-2008 10:06 PM
