Discuss
No Heat On Kenmore Electric Dryer
 in
Dryer Repair
It's not the circuit breaker and the terminal block on the back of the machine is getting all the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat On Kenmore Electric Dryer
  #1 (permalink)
Old 08-26-2009, 01:57 PM
gmamon gmamon is offline
Junior Member
gmamon is on a distinguished road
Default No Heat On Kenmore Electric Dryer
Model Number: 417.94802301   Brand: Kenmore   Age: 1 - 5 years
It's not the circuit breaker and the terminal block on the back of the machine is getting all the right voltage. do you recommend I check the thermal fuse? If you do, do I have to remove the drum or just the rear panel? And what resistence should the meter show if the fuse is good? If this isn't the way to go what do you recommend?
Related Models
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
  #2 (permalink)
Old 08-26-2009, 03:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
According to the wiring diagram there are three parts involved in the heating circuit which you have to check for continuity:
1. The heating element (#15 on the diagram)
2. The high limit thermostat (#33 on the diagram)
3. The control thermostat (#15 on the diagram)
- The heating element Part number: AP2106978
- The high limit thermostat Part number: AP2131477
- The control thermostat Part number: AP2131509
__________________
  #3 (permalink)
Old 08-26-2009, 04:54 PM
Junior Member
Default
really? the diagram doesn't show a thermal cut-off fuse?
Do you happen to know the best way to get inside this machine to test these electrical components you mentioned? I tried to take the back of the dryer off but the drum seems to be attached to it. Is the drum suppose to be unscrewed from inside were the clothes go?
  #4 (permalink)
Old 08-26-2009, 05:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The access to most of parts is from the front. You have to remove the panel under the dryer, the dryer top panel and the dryer front panel.
__________________
  #5 (permalink)
Old 08-27-2009, 08:44 AM
Junior Member
Default
I'm not sure we're talking about the same type of machine. It's a Laundry Center (one piece) with the dryer on top of the washer.
Do you happen to know where I can get a repair manual with step by step instructions on the tear down of this machine? I did a google search but didn't come up with anything in the way of repair manuals for kenmore washer/dryers. Thanks,Greg
  #6 (permalink)
Old 08-27-2009, 10:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...I'm not sure we're talking about the same type of machine. It's a Laundry Center (one piece) with the dryer on top of the washer...
Yes, I figured it out.
Quote:
...where I can get a repair manual with step by step instructions on the tear down of this machine?...
Even this machine made by Frigidaire, it has Kenmore name on it and all manuals are available through Sears only.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer will not heat Shep Dryer Repair 1 04-14-2009 01:40 PM
Kenmore Electric Dryer Intermittent Heat question bolingmike Dryer Repair 3 02-23-2009 07:28 PM
Electric dryer no heat brian16 Dryer Repair 2 11-12-2008 05:57 AM
Ge Electric Dryer No Heat michael j wasson Dryer Repair 1 10-31-2008 10:26 AM
Kenmore Electric Dryer-No Heat jbarbers Dryer Repair 3 04-17-2008 09:53 AM
