neptune167
#1 Posted : Sunday, April 1, 2012 4:03:16 PM(UTC)
neptune167
I pushed the start button, the timer was moving but the motor didn't start. I have replaced the thermal fuse, drive motor, cycling thermostat, thermal cut-off kit and door switch. However, that still didn't solve the problem.
#2 Posted : Tuesday, April 3, 2012 12:48:44 PM(UTC)
Replacement parts for Whirlpool LEC6848AN1 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
The cycling thermostat and thermal cut-off have no effect on the motor starting.
Here is the start circuit for timed dry.
NEUTRAL , DOOR SWITCH D1/D2 , TIMER SWITCH 4 T/W , motor's centrifugal switch , START and MAIN motor windings , THERMAL FUSE , PUSH TO START RELAY R2/R1 , timer contacts BU/BK , L1 120 volts.
Since you have replaced a lot of the parts all that is left is the timer contacts and the start relay or you have a bad connection in the circuit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LEC6848.pdf (95kb) downloaded 13 time(s).
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11/13/2013 9:39:51 AM(UTC)
Whirlpool Dryer doesn't start (Dryer Repair)
by PrinceEnder 11/4/2012 3:45:25 PM(UTC)
GE Dryer Doesn't Start (Dryer Repair)
by gmoney6 8/1/2012 4:25:24 PM(UTC)
Dryer doesn't start. (Dryer Repair)
by sanmigmike 11/4/2010 12:48:31 PM(UTC)
Whirlpool Electric Dryer doesn't start until timer reaches cool down cycle (Dryer Repair)
by noclaf1 8/19/2009 8:48:21 PM(UTC)
by footsie 2/3/2008 2:29:57 PM(UTC)
by doug7as 1/13/2008 11:29:41 AM(UTC)
