Hello,
I have a Kenmore series 90 gas dryer, the model number is 76912692 and stock number is 76912. The dryer is working fine (???) but does not dry the clothes. It does not get hot at all. Also, everytime I start the dryer, I get a gas smell. I already check the gas valve in the laundry room and it is ok, is not "leaking", so probably is that the tube that allows the gas into the dryer is somehow broken.
Any ideas ???
Thanks, you help is very much appreciated.
