JACKDADDY
#1 Posted : Sunday, August 23, 2009 12:49:53 PM(UTC)
JACKDADDY
Hello. i have a noisy dryer that dries fine. I replaced the rollers and the belt but it's still noisy. All I can think of is the motor needs replacing cuz it sometimes makes a droaning sound in addition to being noisy. The original motor is model: S58NXMKE-6644, Part: 3976707, HP: 1/3 SPL, 120/60, 5.9A, thermally protected CL B AMB40C. It also has 2 navy, 1 white, and 1 purple wires on it. The replacement motor sold to me by a reputable appliance store here looks very similar except it only has 1 navy wire, and (I think) 2 bare copper wires. The replacement model: S58NXNBG-7015, part: 8066207, HP: 1/3 SPL, 120/60, 6.5A, Thermally protected CL B AMB40C.
Before buying the repl motor i thought all i had to do was disconnect the white dryer harness plug-in connector from the original motor and connect it to a replacement motor. But with those different wires and different part/model nos/amperage I was (a) wondering if the replacement motor is ok to use by simply plugging the dryer harness connector to it?, and (b) what is the appropriate part number/model number to use as a replacement whirlpool motor if not?
oh, and (c) is there something else I should replace to solve the noisy concern instead of the motor? sorry for being long winded and thanks for your help.
sidfink43
#2 Posted : Monday, August 24, 2009 3:29:26 PM(UTC)
sidfink43
Hi Jack
It seems like the motor wiring on replacement motors changes all the time. I think you have to go back to the seller and get them to take you through the correct process on connecting it.
Also, while you are in the dryer I would replace the idler as they may also be contributing to your noise.
Good luck.
JACKDADDY
#3 Posted : Monday, August 24, 2009 4:04:01 PM(UTC)
JACKDADDY
Thanks Sid:) I did just that and the dealer assured me the motor is fine and that all I have to do is 'plug and play' with the wire harness connector in the dryer (which is what I hoped from the beginning). Thanks for your response. I did replace the idler roller when I replaced the other rollers if that's what you mean. Thanks...I hope this works otherwise the wife is gonna make me buy a new dryer!
sidfink43
#4 Posted : Monday, August 24, 2009 4:12:15 PM(UTC)
sidfink43
Glad you anticipated me. Let us know how it works out.
