Discuss
No heat in the dryer
 in
Dryer Repair
When my dryer is on, there is not heat. I opend the front and looked at the heating element while
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat in the dryer
  #1 (permalink)
Old 08-23-2009, 12:39 PM
Junior Member
demel is on a distinguished road
Default No heat in the dryer
Model Number: 66912690   Brand: Kenmore   Age: More than 10 years
When my dryer is on, there is not heat. I opend the front and looked at the heating element while it was running and noticed that it is not red or hot. I did not see any part of the element broken.
1) How do I test the element to see if it is not burnt ?
2) W
Related Models
Maytag 66CB MAYTAG LAUNDRY (DRYER GAS)
Hoover 67
Hoover 671
Admiral 671AH RANGE- F/S STD GAS
Admiral 671AH-K RANGE- F/S STD GAS
Admiral 671WH RANGE- F/S STD GAS
Admiral 671WH-K RANGE- F/S STD GAS
Admiral 673AJ-KV RANGE- F/S STD GAS
Admiral 673WJ-KV RANGE- F/S STD GAS
Admiral 674AJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674AJ-EKVW RANGE- F/S STD GAS
Admiral 674AJ-EKW RANGE- F/S STD GAS
Admiral 674WJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674WJ-EKVW RANGE- F/S STD GAS
Admiral 674WJ-EKW RANGE- F/S STD GAS
Admiral 675AJ-KVW RANGE- F/S STD GAS
Admiral 675AK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675AK-KVW RANGE- F/S STD GAS
Admiral 675AM-KSVW RANGE- F/S STD GAS
Admiral 675WJ-KVW RANGE- F/S STD GAS
Admiral 675WK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675WK-KVW RANGE- F/S STD GAS
Admiral 675WM-KSVW RANGE- F/S STD GAS
Admiral 676AJ-KSVW RANGE- F/S STD GAS
Admiral 676AK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AK-KSVW RANGE- F/S STD GAS
Admiral 676AM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AM-KSVW RANGE- F/S STD GAS
Admiral 676WJ-KSVW RANGE- F/S STD GAS
Admiral 676WK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WK-KSVW RANGE- F/S STD GAS
Admiral 676WM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WM-KSVW RANGE- F/S STD GAS
Maytag 67C DRYER- GAS
Hoover 68
Frigidaire 68-1075 TAPPAN DISHWASHER
Frigidaire 68-1085 TAPPAN 24" BUILT-IN DISHWASHER
Magic Chef 68-2534-40 GAS RANGE
Magic Chef 68-253657 GAS RANGE
Magic Chef 68-2543-80 GAS RANGE
Magic Chef 68-2543-87 GAS RANGE
Magic Chef 68-2558-40 GAS RANGE
Magic Chef 68-255850 GAS RANGE
Magic Chef 68-255857 GAS RANGE
Magic Chef 68-2563-87 GAS RANGE
Magic Chef 68-2593-80 GAS RANGE
Magic Chef 68-2593-81 GAS RANGE
Magic Chef 68-2593-87 GAS RANGE
Hardwick 68-2598 GAS RANGE
Magic Chef 68-454650 ELECTRIC RANGE
Magic Chef 68-454657 ELECTRIC RANGE
Magic Chef 68-4567-40 ELECTRIC RANGE
Magic Chef 68-456750 ELECTRIC RANGE
Magic Chef 68-456751 ELECTRIC RANGE
Magic Chef 68-456757 ELECTRIC RANGE
Magic Chef 68-4585-40 ELECTRIC RANGE
Magic Chef 68-4587-87 ELECTRIC RANGE
Hoover 681
Admiral 684AJ-CKV RANGE- S/C F/S GAS
Admiral 684WJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKVW RANGE- S/C F/S GAS
Admiral 685WJ-CKV RANGE- S/C F/S GAS
Admiral 685WJ-CKVW RANGE- S/C F/S GAS
Admiral 686AJ-EKSVW RANGE- S/C F/S GAS
Admiral 686AJ-TKSVW RANGE- S/C F/S GAS
Admiral 686AK-EKSVW RANGE- S/C F/S GAS
Admiral 686AM-CKSV RANGE- S/C F/S GAS
Admiral 686AM-TKS RANGE- S/C F/S GAS
Admiral 686WJ-EKSVW RANGE- S/C F/S GAS
Admiral 686WJ-TKSVW RANGE- S/C F/S GAS
Admiral 686WK-EKSVW RANGE- S/C F/S GAS
Admiral 686WM-CKSV RANGE- S/C F/S GAS
Admiral 686WM-TKS RANGE- S/C F/S GAS
Admiral 687AF-CKVW RANGE- S/C F/S GAS
Admiral 687AJ-EKZW RANGE- S/C F/S GAS
Admiral 687AJ-TKSAW RANGE- S/C F/S GAS
Admiral 687AK-TKSAW RANGE- S/C F/S GAS
Admiral 687AM-TKSAW RANGE- S/C F/S GAS
Admiral 687WF-CKVW RANGE- S/C F/S GAS
Admiral 687WJ-EKZW RANGE- S/C F/S GAS
Admiral 687WJ-TKSAW RANGE- S/C F/S GAS
Admiral 687WK-TKSAW RANGE- S/C F/S GAS
Admiral 687WM-TKSAW RANGE- S/C F/S GAS
Magic Chef 6892VRA RANGE- S/C S/I ELE
Magic Chef 6892VRV RANGE- S/C S/I ELE
Magic Chef 6892VVA RANGE- S/C S/I ELE
Magic Chef 6892VVV RANGE- S/C S/I ELE
Magic Chef 6892XRA RANGE- S/C S/I ELE
Magic Chef 6892XRS RANGE- S/C S/I ELE
Magic Chef 6892XRW RANGE- S/C S/I ELE
Magic Chef 6892XVA RANGE- S/C S/I ELE
Magic Chef 6892XVB RANGE- S/C S/I ELE
Magic Chef 6892XVS RANGE- S/C S/I ELE
Magic Chef 6892XVW RANGE- S/C S/I ELE
Magic Chef 6893VVD RANGE- S/C S/I ELE
Magic Chef 6893VVV RANGE- S/C S/I ELE
Magic Chef 6893XVB RANGE- S/C S/I ELE
Magic Chef 6895VRA RANGE- S/C S/I ELE
Magic Chef 6895VRV RANGE- S/C S/I ELE
Magic Chef 6896VVD RANGE- S/C S/I ELE
Magic Chef 6896VVV RANGE- S/C S/I ELE
Magic Chef 6896XVB RANGE- S/C S/I ELE
Magic Chef 6898VRA RANGE- S/C S/I ELE
Magic Chef 6898VRV RANGE- S/C S/I ELE
Magic Chef 6898VVA RANGE- S/C S/I ELE
Magic Chef 6898VVD RANGE- S/C S/I ELE
Magic Chef 6898VVV RANGE- S/C S/I ELE
Magic Chef 6898XRA RANGE- S/C S/I ELE
Magic Chef 6898XRB RANGE- S/C S/I ELE
Magic Chef 6898XVB RANGE- S/C S/I ELE
Magic Chef 68HA-3CW RANGE- S/C S/I ELE
Magic Chef 68HA-3CXW RANGE- S/C S/I ELE
Magic Chef 68HA-4TVW RANGE- S/C S/I ELE
Magic Chef 68HA-4TXW RANGE- S/C S/I ELE
Magic Chef 68HA-6TVW RANGE- S/C S/I ELE
Magic Chef 68HK-6TXW RANGE- S/C S/I ELE
Magic Chef 68HN-3CXW RANGE- S/C S/I ELE
Magic Chef 68HN-4TVW RANGE- S/C S/I ELE
Magic Chef 68HN-4TXW RANGE- S/C S/I ELE
  #2 (permalink)
Old 08-24-2009, 04:22 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You will need a multi meter to test the electrical components
First check to see if you have 120v to each side of the connector block. Then check each of the thermal fuses/thermostats for continuity. Finally check the heating element for resistance. You will need to pull it out to see that it is not broken, and it should have 12 to 20ohms.
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
