Discuss
Maytag Electric Dryer Won't Heat
 in
Dryer Repair
My electric dryer stopped heating. I have checked & double checked continuity on the heating coils, both thermal fuses, hi-limit
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Electric Dryer Won't Heat
  #1 (permalink)
Old 08-23-2009, 10:29 AM
Junior Member
ayersl is on a distinguished road
Default Maytag Electric Dryer Won't Heat
Model Number: LDE8406ACE   Brand: Maytag   Age: More than 10 years
My electric dryer stopped heating. I have checked & double checked continuity on the heating coils, both thermal fuses, hi-limit thermostat, and the thermostat with five lugs (I get continuty on the opposite end lower lugs). All check out ok. What else could it be? I checked the outlet and have 240v across the two side lugs, 120v between others. It appears that the heating system is not getting power. Could it be a moisture sensor, conrol knob, or what????? HELP! BTW, I get 0 ohms across the lheating element leads, and I have disconnected one side of all things before I measure.
Ads By Google
Related Models
Maytag LDE8406ACE Dryer - Ele
Maytag LDE8406ACM Dryer - Ele
Maytag LDE8406ADE Dryer - Ele
Maytag LDE8410 Dryer - Ele
Maytag LDE8410ACE Dryer - Ele
Maytag LDE8410ACL Dryer - Ele
Maytag LDE8410ACW Dryer - Ele
Maytag LDE8410ADE Dryer - Ele
Maytag LDE8410ADL Dryer - Ele
Maytag LDE8410ADW Dryer - Ele
Maytag LDE8410W Dryer - Ele
Maytag LDE8414ACE Dryer - Ele
Maytag LDE8414ACL Dryer - Ele
Maytag LDE8414ACM Dryer - Ele
Maytag LDE8414ADE Dryer - Ele
Maytag LDE8416ACE Dryer - Ele
Maytag LDE8416ACM Dryer - Ele
Maytag LDE8416ADE Dryer - Ele
Maytag LDE8420 Dryer - Ele
Maytag LDE8420ACL Dryer - Ele
Maytag LDE8420ACW Dryer - Ele
Maytag LDE8420ADL Dryer - Ele
Maytag LDE8420ADW Dryer - Ele
Maytag LDE8424ACE Dryer - Ele
Maytag LDE8424ACL Dryer - Ele
Maytag LDE8424ACM Dryer - Ele
Maytag LDE8424ADE Dryer - Ele
Maytag LDE8424ADL Dryer - Ele
Maytag LDE8426ACE Dryer - Ele
Maytag LDE8426ACM Dryer - Ele
Maytag LDE8426ADE Dryer - Ele
International LDE8426GGE Dryer - Ele
Maytag LDE8500 Dryer - Ele
Maytag LDE8500ACL Dryer - Ele
Maytag LDE8500ACW Dryer - Ele
Maytag LDE8506ACE Dryer - Ele
Maytag LDE8506ACM Dryer - Ele
Maytag LDE8506ADE Dryer - Ele
Maytag LDE8600 Dryer - Ele
Maytag LDE8600ACL Dryer - Ele
Maytag LDE8600ACW Dryer - Ele
Maytag LDE8600ADL Dryer - Ele
Maytag LDE8600ADW Dryer - Ele
Maytag LDE8604ACE Dryer - Ele
Maytag LDE8604ACL Dryer - Ele
Maytag LDE8604ACM Dryer - Ele
Maytag LDE8604ADE Dryer - Ele
Maytag LDE8604ADL Dryer - Ele
Maytag LDE8604ADM Dryer - Ele
Maytag LDE8606ACE Dryer - Ele
Maytag LDE8606ACM Dryer - Ele
Maytag LDE8606ADE Dryer - Ele
Maytag LDE8616ACE Dryer - Ele
Maytag LDE8616ACM Dryer - Ele
Maytag LDE8624ACE Dryer - Ele
Maytag LDE8624ACL Dryer - Ele
Maytag LDE8624ACM Dryer - Ele
Maytag LDE8624ADE Dryer - Ele
Maytag LDE8626ACE Dryer - Ele
Maytag LDE8626ACM Dryer - Ele
Maytag LDE8626ADE Dryer - Ele
Maytag LDE8704ACE Dryer - Ele
Maytag LDE8704ACL Dryer - Ele
Maytag LDE8704ACM Dryer - Ele
Maytag LDE8706ACE Dryer - Ele
Maytag LDE8706ACM Dryer - Ele
Maytag LDE8706ADE Dryer - Ele
Whirlpool LDE8800W0
Whirlpool LDE8800W1
Maytag LDE8804ACE Dryer - Ele
Maytag LDE8804ACL Dryer - Ele
Maytag LDE8804ACM Dryer - Ele
Maytag LDE8804ADE Dryer - Ele
Maytag LDE882 Dryer - Ele
Maytag LDE8824ACE Dryer - Ele
Maytag LDE8824ACL Dryer - Ele
Maytag LDE8824ACM Dryer - Ele
Maytag LDE8824ADE Dryer - Ele
Maytag LDE882D Dryer - Ele
Maytag LDE8904ACE Dryer - Ele
Maytag LDE8904ACL Dryer - Ele
Maytag LDE8904ACM Dryer - Ele
Maytag LDE91 Dryer - Ele
Norge LDE912700 Dryer - Ele
Norge LDE912724 Dryer - Ele
Norge LDE9127A Dryer - Ele
Norge LDE9127H Dryer - Ele
Norge LDE9127S Dryer - Ele
Norge LDE9127W Dryer - Ele
Maytag LDE9206ACE Dryer - Ele
Maytag LDE9206ACM Dryer - Ele
Maytag LDE9206ADE Dryer - Ele
Maytag LDE9304ACE Dryer - Ele
Maytag LDE9304ACL Dryer - Ele
Maytag LDE9304ACM Dryer - Ele
Maytag LDE9304ADE Dryer - Ele
Maytag LDE9304ADL Dryer - Ele
Maytag LDE9304ADM Dryer - Ele
Maytag LDE9304AEE Dryer - Ele
Maytag LDE9306ACE Dryer - Ele
Maytag LDE9306ACM Dryer - Ele
Maytag LDE9306ADE Dryer - Ele
Maytag LDE9306ADM Dryer - Ele
Maytag LDE9306AEE Dryer - Ele
Maytag LDE9314ACE Dryer - Ele
Maytag LDE9314ACL Dryer - Ele
Maytag LDE9314ACM Dryer - Ele
Maytag LDE9314ADE Dryer - Ele
Maytag LDE9316ACE Dryer - Ele
Maytag LDE9316ACM Dryer - Ele
Maytag LDE9316ADE Dryer - Ele
Maytag LDE9334ACE Dryer - Ele
Maytag LDE9334ACL Dryer - Ele
Maytag LDE9334ACM Dryer - Ele
Maytag LDE9334ADE Dryer - Ele
Maytag LDE9606ACE Dryer - Ele
Maytag LDE9606ACM Dryer - Ele
Maytag LDE9606ADE Dryer - Ele
Maytag LDE9606ADM Dryer - Ele
Maytag LDE9606AEE Dryer - Ele
  #2 (permalink)
Old 08-24-2009, 09:18 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
To test for continuity and resistance you need to disconnect both lead and use the meter to make a complete circuit. You should have 10 to 20ohms in your heating element.
Test again and let us know what you find out.
__________________
  #3 (permalink)
Old 08-24-2009, 11:22 AM
Junior Member
Default
The problem seemed to be that the circuit wasn't getting any power; I checked power at outlet, it was good. I finally opened the terminal block access & found that the light blue wire attached to L2 (red wire form outlet) had separated from the mounting lug and was just hanging. Turns out the nut holding it down was loose & the loose connection melted the solder at the wire where it connected to the lug. I installed a new lug to the wire, tightened all connections & the dryer works fine! I'm just glad it didn't result in a fire or other calamity! Thanks for your help; I learned a lot about how this dryer works (too much!).
  #4 (permalink)
Old 02-26-2010, 01:43 PM
Junior Member
kit58105 is on a distinguished road
Default
my dryer runs fine but no heat. I think I have the same type of problem. I think its the cycling thermostat. the two small lugs are the bias heater. the one lug and the lower lug on the one end are connected, until heating. I assume the upper lug should connect when it clicks and disconnect the lower, but mine does not.
it is bad? all my fuses and element are ok, post this thermostat.
  #5 (permalink)
Old 02-26-2010, 01:53 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Kit58105: post your model number.
You're correct about the bias heater lugs. The way the thermostat works is that it has continuity between the two larger lugs, so that electricity can flow through it to the heating element. When a certain desired temperature is reached, however, the click you hear is the bimetal contact bending away from one of the lugs, breaking the electron flow to the element. In normal operation, as the thermostat cools, it clicks back into its normally closed position, again allowing electron flow. Check it when it's cool by separating it from its wires, and checking across the two larger lugs for continuity.
  #6 (permalink)
Old 02-26-2010, 02:22 PM
Junior Member
Default
sorry MDE6460ayw.
when you say larger lugs, there are 3 of the same size
1 at one end and 2 at the other. it seems that if that is for the heating element it should not be the problem. because if it's closed the element should work. so maybe temp switch?
  #7 (permalink)
Old 02-26-2010, 02:36 PM
Senior Expert
APP Volunteer
Default
Your dryer has three thermostats: The cycling thermostat, located on the blower housing Part number: AP4038076
It has the bias heater discussed above. The hi-limit thermostat (the one with the three wires) is located on the heater housing. Measure resistance across the single and the top of the double terminals Part number: AP4036890
Then the thermal fuse. If it's blown, the motor won't even run. Part number: AP4043259
  #8 (permalink)
Old 02-26-2010, 03:09 PM
Junior Member
Default
I have the one with 5 lugs..2 for the bias heater, and 3 other lugs. the others test fine at room temp.
the 5 lug thermostat has 2 connected at room temp, that disconnect upon heating and there is no continuity between any of the 3 that are not the bias heater
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Electric Dryer No Heat linktlife Dryer Repair 7 11-03-2009 04:07 PM
Maytag electric dryer heat stays on SusanMKoehler@comcast.net Dryer Repair 2 10-27-2009 01:39 PM
Maytag Electric Range - Lights on but no heat bunangst Oven Repair (including Ranges and Cooktops) 5 10-05-2009 06:49 AM
Maytag Electric Wall Oven upper bake element won't heat Keithmcelroy Oven Repair (including Ranges and Cooktops) 0 09-06-2009 09:52 AM
Amana/Maytag Electric oven won't heat above 250 quickmom Oven Repair (including Ranges and Cooktops) 1 06-11-2009 02:53 PM
