| » Whirlpool Drye No Heat |
Model Number: LER4634PQO Brand: Whirlpool Age: 1 - 5 years
DRYER RUNS BUT HEATER DOES NOT COME ON. HAVE 120 VOLTS TO ONE TERMINAL OF HEATING ELEMENT (power is through thermal fuse side), other terminal has no power, measuring with wire disconnected.
With the wires connected to the terminal block you should have 120v on each side.
If this checks out, test your thermal fuses/thermostats and finally test the heating coil. It should have continuity, 10 to20 ohms resistance and check to make sure it is not grounded.
__________________
| Display Modes | |
| Whirlpool LGR5636LQ0 - No Heat | mcn5067 | Dryer Repair | 10 | 06-10-2010 09:41 AM |
| Whirlpool won't heat | mts3 | Dryer Repair | 1 | 07-13-2009 07:02 PM |
| Whirlpool With No Heat | KIERSTEADL | Dryer Repair | 1 | 04-03-2009 04:09 PM |
| Whirlpool AC/Heat pump - no heat | martydoug@gmail.com | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 11-05-2008 12:25 PM |
| whirlpool dryer no heat | looie | Dryer Repair | 3 | 09-30-2008 07:54 PM |
