Discuss
Kenmore dryer won't fire after first cycle
 in
Dryer Repair
My Kenmore gas dryer was running for 10 hours on the auto cycle. When I restart it the burner would
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer won't fire after first cycle
  #1 (permalink)
Old 01-17-2008, 07:00 PM
Kev Kev is offline
Junior Member
Kev is on a distinguished road
Default Kenmore dryer won't fire after first cycle
Model Number: 110.70702990   Brand: Kenmore   Age: 1 - 5 years
My Kenmore gas dryer was running for 10 hours on the auto cycle. When I restart it the burner would fire for about 10 minutes, shut off and then it would not fire again. The igniter glows but it won't fire. I open the door to stop it, start it back up and it repeats the above. I found a plant outside had fallen in front of the vent so after clearing that out I took the back off and cleaned the entire exhaust ductwork. I put it back together and got the same thing. I replaced the thermostat, internal bias (part# 3387134 41) thinking the heat burnt it out and thought it was fixed because the burner stayed on for 15 minutes or so but then the same thing happened. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 11:07 AM
Kev Kev is offline
Junior Member
Default Problem Solved
I never received a reply, however after reading other posts with the same issue I took a guess and replaced the ignition coil - valve and it fixed my problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore knocks on spin cycle BigDoofus Washer Repair 1 01-14-2008 08:46 PM
oven won't fire curt Oven Repair (including Ranges and Cooktops) 1 12-06-2007 02:39 PM
Burner won't fire up warezaholic Dryer Repair 2 12-02-2007 05:22 PM
Oven Won't Fire OttoZ Oven Repair (including Ranges and Cooktops) 0 11-11-2007 10:07 AM
dryer does not fire Captain Carquest Dryer Repair 1 08-20-2007 10:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
