Discuss
General Dryer Question
 in
Dryer Repair
Does the heating element stay on the whole drying cycle ,or will it come on and off per the thermostat?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » General Dryer Question
  #1 (permalink)
Old 08-22-2009, 09:30 AM
73Ghia 73Ghia is offline
Junior Member
73Ghia is on a distinguished road
Default General Dryer Question
Brand: Kenmore   Age: Less than 1 year
  #2 (permalink)
Old 08-23-2009, 11:07 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
The heating element cycles on and off by the operations of a thermostat.
If it stays on continually you will have a very hot dryer which should blow the thermal fuses/thermostats.
__________________
  #3 (permalink)
Old 08-24-2009, 04:05 AM
Junior Member
Default Dryer Heating Element
Even after changing the High Temp sensor and the Thermostate next too the Element; the Heating Element will come on at the start of the Cycle but then turns off; leaving the clothes damp(yes all vent checks; clean etc). Does this mean the ceramic circuit on the Element is bad? When I check the ELement with a circuit tester, it reads around 10-12 ohms
  #4 (permalink)
Old 08-24-2009, 06:03 AM
Senior Expert
APP Volunteer
Default
The heating element is at the low end of the range, but that seems ok.
You should have a cycling thermostat also, which can be the problem but since you have not posted a model number I cannnot say definitely what is on your machine. Look for a thermostat on or near the vent housing. If you need more info please post the model number.
Good luck.
__________________
  #5 (permalink)
Old 08-24-2009, 06:12 AM
Junior Member
Default
model 11068532700; kenmore 500, 1 year old. The Element will work fine for maybe one load, then only half way 10mins on the next load; even if the load is the next day, not right after.
  #6 (permalink)
Old 08-24-2009, 07:03 AM
Senior Expert
APP Volunteer
Default
An intermittent problem like you have is very difficult to diagnose because a defective part will test out ok, and unfortunately one ends up changing out parts without a definite diagnosis.
As a start I am going to suggest you change out the cycling thermostat, for about $20 including shipping. Here is the part.
Part number: AP3131939
If you do that, test the dryer in all cycles (timed, auto, perm press etc) to see if the problem is in one cycle or all, and if it you are still having problem report back what you found out.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
general question Glenn_7 Oven Repair (including Ranges and Cooktops) 4 06-02-2009 01:23 AM
General Electric dryer won't heat up rod_44 Dryer Repair 5 08-10-2008 03:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
