LG Tromm Dryer Won't Heat
Dryer Repair
I've got a dryer that won't heat on any setting, but otherwise seams to be running (lots of air-flow). It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG Tromm Dryer Won't Heat
  #1 (permalink)
Old 08-22-2009, 08:33 AM
Junior Member
MBryga is on a distinguished road
Default LG Tromm Dryer Won't Heat
Model Number: DLG0332W   Brand: -other-   Age: 1 - 5 years
I've got a dryer that won't heat on any setting, but otherwise seams to be running (lots of air-flow). It came with the house when we bought it 15 months ago (so it's out of any manufacturers and new home warranty). When first powered up, the 'check filter' LED was flashing and the filter was very dirty. We've cleaned the filter with a specifically designed brush and vacuumed what we could, but the LED continues to flash on power-up. When running the LEDs for 'drying' are all flashing in unison (I don't know what they used to do). I ran the diagnostics as per page 16 of the service manual. I found I could wipe the moisture sensors and then run through the tests and I think it verified the moisture sensor is working. After pushing the start/pause button I get the following; 0) no error codes 1) 237 down to 120 2) 24 3) 23 Door Open) dE This all seams normal as far as I can tell. I have not been brave enough to start disassembling the unit to get to the gas valve or thermoswitches to test them (the manual says you have to remove the drum to get to them) Your advice please.
Related Models
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
General Electric DLL6850BAL Gas dryer
General Electric DLL6850BBL Gas dryer
General Electric DLL6850BCL Gas dryer
General Electric DLL6850BDL Gas dryer
General Electric DLL6850BEL Gas dryer
General Electric DLL6850BFL Gas dryer
General Electric DLL6850BGL Gas dryer
General Electric DLL6850TA Electric dryer
General Electric DLL7596ABL Electric dryer
  #2 (permalink)
Old 05-15-2011, 09:28 AM
Junior Member
lynnmcclough is on a distinguished road
Was there an answer to the problem of the dryer not heating? I have the exact same problem. LG gas dryer model#DLG5932S. I have had two technicians out and no one can solve the problem. It was suggeted that the gas value be replaced with no success. Secondly, an LG support tech informed the repair tech the motor needed to be replaced. There was a bad sensor inside the motor. After ordering the new motor and replacing in dryer, the problem was still not resolved. Any assistance would be appreciated.
  #3 (permalink)
Old 05-15-2011, 09:43 AM
Junior Member
Default Dryer Repired
We ended up hiring an LG repairman, and he replaced 2 sensors (enither in the motor itself). It was quite a job to dissemble the unit to get to them, but he really knew what he was doing.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tromm lg afloflo Washer Repair 1 05-28-2011 06:40 AM
How to remove front cover LG Tromm jpstiles02 Dryer Repair 1 01-11-2010 03:05 AM
LG Tromm IE error code Camey Washer Repair 0 11-23-2009 07:21 PM
LG tromm 5932 wont start radar6 Dryer Repair 0 10-11-2009 01:37 PM
LG Tromm deang007 Washer Repair 1 08-22-2009 10:46 AM
