I am trying to remove the heating element housing to change the element. The only screws that I can see to remove the housing are in between the housing and the dryer tub. The screw is visible in the picture I have attached. There is little or no room to remove that screw. I do not see how it can be done. If someone could help with this that would be excellent and much appreciated. Thanks Rick kingrick attached the following image(s):
Groups: APP Team
Hi.
To help you I need a better picture or correct model number. Please check and post.
Thank you. Simon.
