I must replace the motor (which I believe has failed) that drives the drum. I have removed the front panel, the drum, belt and the 2 clips holding the motor to its bracket. I have also removed the rear panel of the dryer but can't figure out how to get access to the rear of the motor in order to remove it and install the fan/pulley (I assume) to the new motor? Thank you!
