jrnutpaul
#1 Posted : Tuesday, March 27, 2012 8:58:09 AM(UTC)
jrnutpaul
This dryers problem first started with continuous beeping noises after it turned off. Then it would turn itself back on if left plugged in and the lights would light up but it wouldn't start.
To try and reset the control panel I pushed three of the four buttons on the left of the control panel. This started the panel sequencing the lights from left to right in rows. After the lights light up completely it then does this over again.
So, then I pushed the two middle buttons on the left row and the units sequencing stopped. I was able to set it on the cycles I wanted and the start button worked. it dried the clothes, after, it would not turn off. When I manually pushed the off button it went off for a few seconds and then it would relight up. I could then make it work by pushing the start button.
So, what is going on?
#2 Posted : Tuesday, March 27, 2012 6:42:33 PM(UTC)
Most likely the problem is a bad key pad which is a part of the console. There is a small chance for the control board to be bad as well. There are no instrumental tests provided by the manufacturer for such situation. I would replace the console first.
- The console Part number: AP4043542
