Discuss
Gas dryer running but no heat
 in
Dryer Repair
My dryer runs but there is no heat. The timer cycles except on the Automatic setting. There was no glow
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer running but no heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-16-2008, 10:38 AM
RBYRD9.1 RBYRD9.1 is offline
Junior Member
RBYRD9.1 is on a distinguished road
Default Gas dryer running but no heat
Model Number: LGR7648KQ1   Brand: Whirlpool   Age: 5 - 10 years
My dryer runs but there is no heat. The timer cycles except on the Automatic setting. There was no glow at the gas ignitor so I replaced it. Still no glow. Any ideas ????? A sensor maybe? Any help would be much appreciated!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-16-2008, 06:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check for continuity is the thermal fuse (#7 on the bulkhead parts break down diagram).
If the thermal fuse is blown, it has to be replaced together with the cycling thermostat (#9 on the bulkhead parts break down diagram).
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
Here are the break down diagrams for the Whirlpool dryer Model LGR7648KQ1
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-20-2008, 11:39 AM
Junior Member
Default
It was the thermal fuse!!! Thank you for all the links you posted also. Was a major help. Repaired for less than a service call only! My dryer now runs just like it did before...
  #4 (permalink)
Old 01-22-2008, 10:48 AM
missieann33 missieann33 is offline
Junior Member
missieann33 is on a distinguished road
Default no heat and will not stop on it's own
[quote=RBYRD9.1;11797]My dryer runs but there is no heat. I Have a Question. My Dryer will run but has no heat. If you put it on a regular cycle it will run all day and all night. I put it on 70 minute dry and it still has no heat but will stop after 70 minutes.. Anyone have a suggestion?? Thanks
  #5 (permalink)
Old 01-22-2008, 02:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi RBYRD9.1,
I'm glad you were able to fix it.
__________________
  #6 (permalink)
Old 01-22-2008, 02:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi missieann33,
In order to provide the most accurate advise I need the complete model number of the dryer.
Post it as a new thread, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer keeps running, clothes are dry. freerangequark Dryer Repair 2 01-13-2008 12:19 PM
Dryer keeps running and no doesn't heat sheila30083 Dryer Repair 3 11-25-2007 07:50 AM
Dryer running with no heat rotty Dryer Repair 1 11-21-2007 08:45 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
clothes dryer keeps running pookie1954 Dryer Repair 1 08-08-2007 09:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
