Discuss
Dryer problems
 in
Dryer Repair
My Dryer was not starting....I checked the Thermal Fuse....that was the problem...no continuity...I am replacing the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer problems
  #1 (permalink)
Old 01-16-2008, 10:26 AM
Charlie1076 Charlie1076 is offline
Junior Member
Charlie1076 is on a distinguished road
Default Dryer problems
Model Number: SEDX600JQ0   Brand: Whirlpool   Age: 5 - 10 years
My Dryer was not starting....I checked the Thermal Fuse....that was the problem...no continuity...I am replacing the Thermal Fuse.....my question is do I need to change the Thermostat Part Number: AP3131939 as well?
How do I check that Part Number AP3131939 Thermostat to see if that is the problem as well. How do I check the thermostat for Continuity? Which of the four wires should I pull off from the Thermostat and where should my OHM meter be touching to check the Continuity????
When replacing the Thermal Fuse do I need to also replace the Thermostat right below it?
Please help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-16-2008, 02:57 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
If it,s the first time replacing the fuse all I would check would be the dryer vent. Make sure it is not plugged or kinked and that the air flow is good.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer problems/questions jamesb1034 Dryer Repair 1 04-27-2008 02:50 PM
Dryer problems perry1980r Dryer Repair 2 01-09-2008 06:07 PM
Sporadic dryer problems sps2112 Dryer Repair 0 12-30-2007 05:08 PM
Dryer belt problems Kimberli Dryer Repair 1 11-12-2007 04:35 PM
Dryer Problems rr454 Dryer Repair 4 08-09-2007 11:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
