| » whirlpool gas dryer thermal fuse |
Model Number: LGQ9558KQ1 Brand: Whirlpool Age: 5 - 10 years
Dryer will spin with no heat. Tested thermal fuse and it is open. temporarily shorted fuse, and unit seems to heat fine. Do I still need to replace the cycling thermostat?
Quote:
You definitely need to replace the thermal fuse and would probably be a good idea to replace the cycling stat also. You also need to check out your venting also, if it's gotten slow it can cause the thermal to pop. Part number: AP3176214 Part number: AP3045874
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
The part I tested looks like this
Replacement parts for WHIRLPOOL LGQ9558KQ1 | AppliancePartsPros.com |
That is another thermal on the blower. My fault for not asking which one. Other then that, you probably still ought to replace cycle stat and check the vent.
__________________
Quote:
Will do. Thanks for your help |
| Display Modes | |
| Whirlpool Built in Oven - thermal fuse | Pastor George | Oven Repair (including Ranges and Cooktops) | 3 | 12-04-2010 09:44 AM |
| whirlpool dryer thermal fuse | kirks | Dryer Repair | 1 | 02-03-2010 03:01 AM |
| Thermal Fuse for Gas Dryer | bobby h | Dryer Repair | 5 | 08-29-2009 05:02 AM |
| Whirlpool dryer-thermal fuse keeps blowing | needs help | Dryer Repair | 4 | 04-13-2009 03:48 PM |
| Whirlpool Thermal Fuse Blown | gerardjuarez | Dryer Repair | 1 | 05-12-2008 06:58 PM |
