| » Dryer won't start |
Model Number: PYE2300AYW Brand: Maytag Age: 1 - 5 years
Our dryer stopped in the middle of a cycle and wouldn't turn on again. We did some googling and ended up replacing the hi-limit thermostat and the thermal fuse. There was a lot of lint built up so we cleaned that out as well. Turned on the dryer, and the fuse blew within about 5 minutes. Did some more googling, and decided that maybe we didn't get all of the blockage out so we cleaned everything out really well and replaced the fuse again. Again, it blew in about 5 minutes. I did some searching again and called a few people and decided to check the control thermostat. That seemed to be the problem so we replaced it as well as another thermal fuse. Now it won't turn on at all. What could be the problem?
Ok new problem. I got it to start. It will run on no heat but if I put it on a heat setting, it trips the breaker. Ads By Google Related Models Last edited by jlynn : 03-22-2012 at 04:48 PM. |
Yes, it is very possible. You may want to check the heating element for continuity across its terminals and each terminal to the ground. Inspect all wires. Post the results.
- The heating element kit Part number: AP4242494 Here are the breakdown diagrams and Replacement parts for Maytag PYE2300AYW DRYER- ELE | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| HOT POINT DRYER has power but start button doesn't start the dryer. | HOT POINT | Dryer Repair | 2 | 08-01-2011 06:47 PM |
| Dryer wont start, sensing light just flashes when i hold down the start button! | crsteilen | Dryer Repair | 0 | 03-28-2011 03:21 PM |
| Dryer wont start, sensing light just flashes when i hold down the start button! | crsteilen | Dishwasher Repair | 0 | 03-28-2011 12:13 PM |
| Dryer will not start - will power up, but when push the start button, will not start | perduena | Dryer Repair | 0 | 07-12-2010 07:14 PM |
| dryer start button flashing and not clicking to start dryer | lawfamily | Dryer Repair | 0 | 06-21-2010 07:43 PM |
