rrisher
#1 Posted : Tuesday, January 15, 2008 4:37:59 PM(UTC)
rrisher
My dryer will run for a week or so and then it won't start. Press the start button and the timer will tick if it is in any position other than off.
What should I do?
#2 Posted : Wednesday, January 16, 2008 12:35:09 PM(UTC)
Is it completely dead or it's an intermittent?
rrisher
#3 Posted : Friday, January 18, 2008 3:06:27 AM(UTC)
rrisher
It does not run right now. I tested the timer by checking the power wires with a ohm meter. Checked ok.
#4 Posted : Friday, January 18, 2008 10:17:13 AM(UTC)
Check for continuity across the timer terminals "T" & "W".
Replace the timer if it's open.
Check the thermal fuse (#7 on the bulkhead parts break down diagram).
Replace if it's open together with the cycling thermostat (#8 on the bulkhead parts break down diagram).
- The part number for the timer is AP3135794
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
Here are the break down diagrams for the Whirlpool dryer Model LER6611LQ0
rrisher
#5 Posted : Friday, January 18, 2008 4:11:14 PM(UTC)
rrisher
The timer and thermal fuse check ok.
#6 Posted : Saturday, January 19, 2008 12:38:00 PM(UTC)
Check the wires to the motor and resistance across the motor terminals where the white and the blue wires coming to the motor.
Post your findings.
