Discuss
Inherited Dryer Runs but just stopped drying
 in
Dryer Repair
We inherited a Kenmore gas dryer with the house we bought back in March 2007 so I don't know
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Inherited Dryer Runs but just stopped drying
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-15-2008, 04:30 PM
pmueller07 pmueller07 is offline
Junior Member
pmueller07 is on a distinguished road
Default Inherited Dryer Runs but just stopped drying
Model Number: 110.73912100   Brand: Kenmore   Age: 5 - 10 years
We inherited a Kenmore gas dryer with the house we bought back in March 2007 so I don't know how old it is. Until yesterday it was working fine--now it runs but will not heat up at all. I have seen seen a number of possibilities on this site (thermal fuse, heating element, etc.) but I am a novice and don't know where to begin. We're thinking of replacing it since Sears charges $60 just to look at it and we both assume any additional repair cost might be better put toward a new dryer. Any ideas? If it helps the serial # is ML3401979 and type is DDOT-NAT-1206006-CV22. I'd like to know how old it is and would greatly appreciate specific details on any suggestions on how to troubleshoot. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 07:05 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
The easiest and least expensive repair is a thermal fuse. DISCONNECT POWER TO DRYER. Pull dryer out, disconnect dryer vent and proceed to take complete back off dryer. Near the bottom of the dryer you will find a little white part (thermal fuse) has two wires going to it and is held in with a single 1/4" screw. Pull off both those wires on the thermal fuse, tape them together and try the dryer. If it starts, the thermal fuse needs replacing. Also at that time clean dryer and venting and check that your outside vent damper is opening completely. Hope this helps.
  #3 (permalink)
Old 01-16-2008, 07:13 PM
Junior Member
Default
Thanks. I'll give it a try.
  #4 (permalink)
Old 01-17-2008, 05:55 PM
Junior Member
Default
Ok, a couple of things. I tried for a least a half an hour to remove the back of the dryer only to find it welded in some places. Then I went to the front of the dryer to find a panel under the door that popped off with some effort. Here I found the blower motor and was able to clean out most of the dirt inside. My remaining problem is that I am unable to locate the thermal fuse at this point. Any idea where it is located specifically? There are instructions on the blower assembly cover that talk about removing the blower wheel but I am unable to do that either. Please help........
  #5 (permalink)
Old 01-17-2008, 06:44 PM
Junior Member
Default
I found the thermal fuse and pulled off the two wires and connected them together. The dryer still runs but does not provide heat as before. I assume I should check the igniter and gas valve coils next, right? Any specific suggestions on these???
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer not drying enough lt3 Dryer Repair 5 01-04-2008 10:38 AM
Dryer not drying mariebw Dryer Repair 3 12-30-2007 04:39 PM
Dryer stopped mid drying cycle and won't start again scsimpson Dryer Repair 2 11-25-2007 06:44 PM
Dryer not drying sue1759 Dryer Repair 5 11-02-2007 05:09 PM
Top of Dryer hot but clothes not drying sween Dryer Repair 4 10-27-2007 12:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
