Discuss
dryer heats,but does not turn
 in
Dryer Repair
i just replaced the thermal fuse because when i bypassed it the dryer started working.i noticed the heating element glowed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer heats,but does not turn
  #11 (permalink)
Old 08-19-2009, 02:45 PM
Junior Member
boomerang6297 is on a distinguished road
Default repaired
i just replaced the thermal fuse because when i bypassed it the dryer started working.i noticed the heating element glowed cherry red and it did not do that when i had the problem.i think it heated,but not as hot as it is now.one concern is ...i see the heating element does not get red all the way around..only about two thirds around.does that mean the element is broken and should be replaced?
Ads By Google
  #12 (permalink)
Old 08-19-2009, 02:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It's hard to say without seeing the heating element. You have to pull it out and inspect the coils.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 08-19-2009, 03:11 PM
Junior Member
Default element
thanks for the reply.does that get pulled out from the front (whirlpool WES9200SQ0)?thanks
  #14 (permalink)
Old 08-19-2009, 11:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You probably can access it by removing the toe panel.
__________________
  #15 (permalink)
Old 08-20-2009, 05:46 AM
Junior Member
Default thanks
thanks for all the help!!
  #16 (permalink)
Old 08-20-2009, 12:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #17 (permalink)
Old 08-20-2009, 12:53 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Quote:
Originally Posted by kayakcrzy View Post
replace the thermister then. It is in the back and has two wires coming to it. Tom
The thermistor's on the blower housing, in the front of the dryer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer want turn,but heats up SHOSHO45 Dryer Repair 2 03-09-2011 06:33 PM
Dryer heats but won't turn on Yaharacer Dryer Repair 2 10-03-2009 05:49 AM
timer not advancing dryer heats does not turn off hyperlk Dryer Repair 1 09-27-2009 05:55 PM
Dryer heats, moor/drum do not turn appmb923 Dryer Repair 1 08-24-2009 04:27 PM
Dryer Heats...but drum does not turn inside nextel8 Dryer Repair 1 08-23-2009 11:15 AM
