Discuss
MDG5500AWW gas dryer not consistent
 in
Dryer Repair
I bought a used gas dryer from some fly-by-night retailer and I've been having problems ever since. The problem is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » MDG5500AWW gas dryer not consistent
  #1 (permalink)
Old 03-20-2012, 04:50 PM
Junior Member
rje45 is on a distinguished road
Default MDG5500AWW gas dryer not consistent
Model Number: MDG5500AWW   Brand: Maytag   Age: 1 - 5 years
The problem is that it will not heat up after completing a few cycles. I've replaced the coils and the igniter. It may run through an entire load, and it may only run through one burner cycle. Some times, the igniter doesn't kick on at all. The valve relay is closing when it is supposed to.
I took the burner assembly to a local shop twice to have it bench tested and they're telling me its running fine. This was with my flame sensor.
The thermistor is measuring 13k ohms. All of the thermal fuses are measuring normal.
The only thing that is consistent is that when there is a problem, the igniter doesn't relight. By that I mean that the igniter isn't relighting and waiting for the valve to open.
The only other symptom is that a few days ago, there was a noise coming from the valve area that sounded like it may have been clattering. It was a sporadic clatter. After that, the problems seemed to get worse.
Any ideas would be great.
Thanks,
Rob
Ads By Google
Related Models
Maytag MDG5500AWW Dryer - Gas
Maytag MDG5806AWK Dryer - Gas
Maytag MDG5806AWW Dryer - Gas
Maytag MDG5960BWW Dryer - Gas
Maytag MDG6000AWQ Dryer - Gas
Maytag MDG6000AWW Dryer - Gas
Maytag MDG6000AXW Dryer - Gas
Maytag MDG6000BWQ Dryer - Gas
Maytag MDG6000BWW Dryer - Gas
Maytag MDG6200AWQ Dryer - Gas
Maytag MDG6200AWW Dryer - Gas
Maytag MDG6400AWQ Dryer - Gas
Maytag MDG6400AWW Dryer - Gas
Maytag MDG6460AWW Dryer - Gas
Maytag MDG6657BWQ Dryer - Gas
Maytag MDG6657BWW Dryer - Gas
Maytag MDG6700AWM Dryer - Gas
Maytag MDG6700AWW Dryer - Gas
Maytag MDG6800AWB Dryer - Gas
Maytag MDG6800AWQ Dryer - Gas
Maytag MDG6800AWW Dryer - Gas
Maytag MDG7057AWQ Dryer - Gas
Maytag MDG7057AWW Dryer - Gas
Maytag MDG7057BWQ Dryer - Gas
Maytag MDG7057BWW Dryer - Gas
Maytag MDG7400AWQ Dryer - Gas
Maytag MDG7400AWW Dryer - Gas
Maytag MDG7460AWQ Dryer - Gas
Maytag MDG7460AWW Dryer - Gas
Maytag MDG7500AWQ Dryer - Gas
Maytag MDG7500AWW Dryer - Gas
Maytag MDG75MNAWW Dryer - Gas
Maytag MDG75MNVWQ Dryer - Gas
Maytag MDG75MNVWW Dryer - Gas
Maytag MDG75PN1AW Dryer - Gas
Maytag MDG75PN2VW Dryer - Gas
Maytag MDG75PNAVW Dryer - Gas
Maytag MDG75PNHWQ Dryer - Gas
Maytag MDG75PNHWW Dryer - Gas
Maytag MDG75PNVVQ Dryer - Gas
Maytag MDG75PNVVW Dryer - Gas
Maytag MDG75PNVWQ Dryer - Gas
Maytag MDG75PNVWW Dryer - Gas
Maytag MDG7600AWQ Dryer - Gas
Maytag MDG7600AWW Dryer - Gas
Maytag MDG7657AWQ Dryer - Gas
Maytag MDG7657AWW Dryer - Gas
Maytag MDG7657BWQ Dryer - Gas
Maytag MDG7657BWW Dryer - Gas
Maytag MDG7658AWQ Dryer - Gas
Maytag MDG7658AWW Dryer - Gas
Maytag MDG7658BWQ Dryer - Gas
Maytag MDG7658BWW Dryer - Gas
Maytag MDG76PCBWS Dryer - Gas
Maytag MDG76PCBWW Dryer - Gas
Maytag MDG7757AWQ Dryer - Gas
Maytag MDG7757AWW Dryer - Gas
Maytag MDG7758AWQ Dryer - Gas
Maytag MDG7758AWW Dryer - Gas
Maytag MDG77PNAWW Dryer - Gas
Maytag MDG77PNSWW Dryer - Gas
Maytag MDG8000AWQ Dryer - Gas
Maytag MDG8000AWW Dryer - Gas
Maytag MDG8000BWQ Dryer - Gas
Maytag MDG8000BWW Dryer - Gas
Maytag MDG8057AWQ Dryer - Gas
Maytag MDG8057AWW Dryer - Gas
Maytag MDG8057BWQ Dryer - Gas
Maytag MDG8057BWW Dryer - Gas
Maytag MDG8058BWQ Dryer - Gas
Maytag MDG8058BWW Dryer - Gas
Maytag MDG8400AWQ Dryer - Gas
Maytag MDG8400AWW Dryer - Gas
Maytag MDG8416AWA Dryer - Gas
Maytag MDG8416AWW Dryer - Gas
International MDG8426AAW Dryer - Gas
International MDG8426AEW Dryer - Gas
International MDG8426AGW Dryer - Gas
Maytag MDG8500BWW Dryer - Gas
Maytag MDG8506AWA Dryer - Gas
Maytag MDG8506AWW Dryer - Gas
International MDG8550AGW Dryer - Gas
International MDG8550BGW Dryer - Gas
Maytag MDG8600AWQ Dryer - Gas
Maytag MDG8600AWW Dryer - Gas
Maytag MDG8757AWQ Dryer - Gas
Maytag MDG8757AWW Dryer - Gas
Maytag MDG9206AWA Dryer - Gas
Maytag MDG9206AWW Dryer - Gas
Maytag MDG9206AXW Dryer - Gas
Maytag MDG9206BWW Dryer - Gas
Maytag MDG9306AWA Dryer - Gas
Maytag MDG9306AWW Dryer - Gas
Maytag MDG9306AXA Dryer - Gas
Maytag MDG9306AXW Dryer - Gas
Maytag MDG9316AWA Dryer - Gas
Maytag MDG9316AWQ Dryer - Gas
Maytag MDG9316AWW Dryer - Gas
Maytag MDG9316AXW Dryer - Gas
Maytag MDG9316BWQ Dryer - Gas
Maytag MDG9316BWW Dryer - Gas
Maytag MDG9357AWA Dryer - Gas
Maytag MDG9357AWQ Dryer - Ele
Maytag MDG9357AWW Dryer - Gas
Maytag MDG9360BWW Dryer - Gas
Maytag MDG9390AWW Dryer - Gas
Maytag MDG9390AXW Dryer - Gas
Maytag MDG9390BWW Dryer - Gas
Maytag MDG9420BWW Dryer - Gas
Maytag MDG9520BWQ Dryer - Gas
Maytag MDG9520BWW Dryer - Gas
Maytag MDG9557AWA Dryer - Gas
Maytag MDG9557AWQ Dryer - Gas
Maytag MDG9557AWW Dryer - Gas
Maytag MDG9557AXQ Dryer - Gas
Maytag MDG9557AXW Dryer - Gas
Maytag MDG9557BWQ Dryer - Gas
Maytag MDG9557BWW Dryer - Gas
Maytag MDG9606AWA Dryer - Gas
Maytag MDG9606AWQ Dryer - Gas
  #2 (permalink)
Old 03-21-2012, 11:39 AM
Gary/APP Team's Avatar
Expert
Gary/APP Team is on a distinguished road
Default
Hello. If you have replaced the coils and the igniter, to answer one part of your question , the igniter has to get hot and glow before the valve opens here is what you test for, Test for 3.2-3.6 volts AC at the gas safety valve with the igniter turned on. If the voltage is there, you have a bad safety valve. If the voltage is low, you have a weak igniter and the igniter will need to be replaced. You can test this with a Part number: AP3440648
Here is a link on how to use a multi-meter. Hope this helps. How To Check Continuity With Ohmmeter
next the sound that you are hearing at the valve is usually low gas pressure or empty tank I have seen it several times most likely this is it thank you and good luck
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-21-2012, 12:02 PM
Junior Member
Default
Where on the valve should I test for voltage? I'm seeing 120v image black and red wires (if memory serves) at the coils. When the igniter is charged, it flows very bright.
I don't have a tank, so I don't know how to check for low gas pressure.
Thanks for the reply.
Rob
  #4 (permalink)
Old 03-21-2012, 01:41 PM
Expert
Default
Hello Rob. Check the coils and see if they test good. You can test the coils using a multi-meter The two prong coil will read 1,000-1,300 ohms, and the three prong coil will read 1,300-1,400 ohms across prongs 1&2, and 500-600 ohms across prongs 1&3. Test the coils after running the dryer for about 10 minutes.
__________________
  #5 (permalink)
Old 03-21-2012, 02:52 PM
Junior Member
Default
I'll test that as soon as I get home.
If the igniter doesn't light up after the first cycle, would that indicate a bad cool?
  #6 (permalink)
Old 03-21-2012, 03:02 PM
Expert
Default
Hello. Yes sir that would be right, thank you and good luck !
__________________
  #7 (permalink)
Old 03-21-2012, 05:24 PM
Junior Member
Default
I tested the coils and here are the results:
Two-prong: 1400
Three-prong pin 1 - 2: 1409
Three-prong pin 2 -3: 590
when I started the dryer (from cold), it ran until the temp reached 30 degrees (c). The relay opened, the valve shut off. It ran with the valve off while the temp slowly continued to rise. After a few minutes, the relay closed and the igniter and valve came on. The valve stayed open until the temp reached 68 degrees. The valve closed and the dryer cooled to 58. I could hear the relay close again, but the igniter didn't come back on. The igniter is only two days old and burns great when it lights up. I tested the resistance across the igniter before and after the cycle, and it is good.
The strange thing is that the dryer will not heat at all after it cuts out on me unless I let it site for a long time (over an hour at least).
Any ideas?
  #8 (permalink)
Old 03-22-2012, 06:04 AM
Expert
Default
Hello Rob . You will need to replace the coils they aer breaking down.
__________________
  #9 (permalink)
Old 03-24-2012, 09:59 AM
Junior Member
Default
Thanks Gary. I ordered some new coils. I had already orders a new thermistor before posting on here at the advice of a local shop. Of course that didn't work.since I replaced the thermistor, the igniter hasn't come on at all (with either thermistor installed). Hopefully I didn't screw something up when I did that.
What causes the coils to go bad? The coils in there now are only a month old. If the new ones come in and work, I'll get my money back. Is there anything that I can do to prevent the new, new coils from going bad after such a short time?
  #10 (permalink)
Old 03-24-2012, 10:32 AM
Junior Member
Default
I think I found the culprit. There's a blown resistor on the controller. It looks like r54. I'm going to head to the electronics shop and see if I can replace it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer MDG5500AWW control panel flashing ThomasM Dryer Repair 0 10-13-2011 06:26 PM
Element Heat not Consistent jk1971 Oven Repair (including Ranges and Cooktops) 1 03-31-2011 07:35 PM
Admiral Gas Dryer not consistent anwaaruth Oven Repair (including Ranges and Cooktops) 0 03-02-2011 05:44 PM
Maytag MDG5500AWW gas dryer acting up broncobcc Dryer Repair 1 09-16-2010 04:38 PM
Maytag MDG5500AWW Neptune dryer temperature control weirdness jwalker123 Dryer Repair 0 10-19-2009 11:11 PM
