Discuss
kenmore laundry center thermal limiter
 in
Dryer Repair
I have a kenmore laundry center dryer 417.99980120 that would not start. I order a repair manual and found
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore laundry center thermal limiter
  #1 (permalink)
Old 01-15-2008, 12:58 PM
sunshine5500 sunshine5500 is offline
Junior Member
sunshine5500 is on a distinguished road
Default kenmore laundry center thermal limiter
Model Number: 417.99980120   Brand: Kenmore   Age: More than 10 years
I have a kenmore laundry center dryer 417.99980120 that would not start. I order a repair manual and found that the themal limiter needed to be replaced. I replaced it and cleaned out entire unit and the dryer vent. It started and ran for 10 min. and will not start again. Really upset because it is in a very tight spot. I would like to know what else could cause thermal limiter to trip and and what else could i have missed. oh, I also need a wiring diagram, please send copy if possible. thanks in advance for your help.
sharla
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-16-2008, 01:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
An air flow restrictions resulting in longer drying times, hotter dryer surfaces and in extreme cases causing the thermal limiter to open on electric dryers.
Restrictions can occur any places in the air flow system, but the most common are:
1. Installing the laundry center in a small enclosed area; such as a closet without a louvered door, that reduces the intake air.
2. Fan problems caused by either a slow running motor, a broken or deformed blower wheel or a deformed fan housing.
3. A lint restriction in the lint screen area.
4. A restriction in the exhaust system in the house caused by the design of the vent, such as: the diameter of the vent pipe being too small, too long or too many angles, a collapsed or lint restricted vent pipe.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 07:52 PM
center seal grease looz98 Washer Repair 1 01-09-2008 03:17 PM
Kenmore Laundry Center - Washer Clutch Question... ascdesigns Washer Repair 1 01-02-2008 11:21 AM
Washer leaks at the center of the tub presmique Washer Repair 9 12-27-2007 04:27 AM
no power to microwave cooking center colonialfan Microwave Repair 1 08-21-2007 05:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
