Discuss
Dryer does not start all the time???
 in
Dryer Repair
OK...sorry....on the right hand side on the timer there are 4 wires looks like this _ wire(white)
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not start all the time???
  #11 (permalink)
Old 01-16-2008, 02:29 PM
gthoman gthoman is offline
Junior Member
gthoman is on a distinguished road
Default
_
wire(white)
wire(white,going into plastic piece)
W
_
wire(tan)
wire(tan, going into plastic piece)
opening of plastic piece(no wire)
connector for wire(but nothing attached)
T
So it seems T already doesn't have anything attached....but maybe I'm reading it wrong...Also I tried to pull the top wire(white) and the plastic piece would not let it come all the way out....I was afraid to pull this off....Does it just come off??......Thanks again for all the help......
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 01-16-2008, 03:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I did not mean the color of the wires. All timer terminals should have a letter marks as shown on the timer picture on the wiring diagram sheet.
So we are talking about two timer terminals, marked "T" & "W".
__________________
Professional appliance repair in Los Angeles, California.
  #13 (permalink)
Old 01-16-2008, 03:24 PM
Junior Member
Default
Yes...I understand you were talking about the letter marks..But as I showed in the previous thread there are 2 wires that connect above the "W" and both seemed to be related to the "W". At the bottom right on the timer there is a "T". Directly above the "T" there is a terminal that does not have a wire going into it, and directly above that is an opening of this plastic piece that also does not contain a wire.....So, does this mean the "T" is already removed or is it the other two wires above that??....Hope this makes sense.......
Thanks...
  #14 (permalink)
Old 01-18-2008, 12:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry, I can not understand what is the "plastic piece".
If you can post a couple of timer pictures, it will help me to see what is going on with the timer.
__________________
  #15 (permalink)
Old 01-22-2008, 09:20 PM
Junior Member
Default
Sorry for the late reply....It was a bad timer, I replaced it and the dryer started working.....Thanks for all the help...
  #16 (permalink)
Old 01-23-2008, 10:28 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer doesn't start doug7as Dryer Repair 1 01-20-2008 12:48 PM
Dryer won't start shangki Dryer Repair 1 12-17-2007 09:16 PM
Whirlpool Dryer Element On All the Time pkp7071 Dryer Repair 1 12-12-2007 07:55 PM
Dryer Won't Start mdcorbell Dryer Repair 0 11-21-2007 01:17 AM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 03:48 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
