Discuss
Maytag dryer help
 in
Dryer Repair
Hello! My Maytag electic Intellidry dryer makes a screeching metal-on-metal sound on-and off. How do I open
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer help
  #1 (permalink)
Old 01-15-2008, 11:06 AM
maytag bob maytag bob is offline
Junior Member
maytag bob is on a distinguished road
Unhappy Maytag dryer help
Model Number: MDE9606AYW   Brand: Maytag   Age: 5 - 10 years
Hello!
How do I open the lid to look inside?
What are a few possible sources of the noise?
Maytag Bob
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 07:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Bob,
Remove the one screw from each door hinge and remove the door.
Remove the two screws on other side of the door frame.
Grab the top of the front panel on each side, pull and turn it from inside out to release it from the clip. Pull the top of the front panel toward yourself to release from the bottom clips.
Remove the screw on top on each side held the security hook. Remove the security hooks.
Remove the two screws on each side held the shroud. Remove the shroud.
Remove the belt from the motor pulley and pull out the drum.
Inspect the idler pulley, the drum support rollers (on the back), the belt and the drum bearings (in the front) for wear and/or damages.
Check the blower wheel.
Replace all worn out and/or damaged parts. Clean the dryer inside.
- The part number for the bearing kit is AP4037304
- The part number for the drum support roller is AP204721
- The part number for the belt is AP285924
- The part number for the idler pulley is AP285227
- The part number for the blower wheel is AP285234
Here are the break down diagrams for the Maytag dryer Model MDE9606AYW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-16-2008, 03:38 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
From Bob's email:
That's a great summary. I'll dig in in the morning!
Bob
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer not heating sparki3 Dryer Repair 0 01-13-2008 10:44 AM
Maytag Dryer derwin Dryer Repair 0 11-16-2007 07:07 PM
Maytag dryer ARRABITOT Dryer Repair 2 10-20-2007 03:37 AM
Maytag nemtune dryer cdeer77 Dryer Repair 0 10-06-2007 02:29 PM
Maytag dryer squeeks Brian Dryer Repair 1 08-28-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
